MARTINS Posted December 6, 2010 Report Share Posted December 6, 2010 Wanting to put Mich LTX MS2 tires on my 2008 edge FWD. They do not make a 235/65-17 so will a 235/70-17 fit? Need to know. thanks Quote Link to comment Share on other sites More sharing options...
LIVIO Posted December 7, 2010 Report Share Posted December 7, 2010 On 12/6/2010 at 5:22 PM, MARTINS said: Wanting to put Mich LTX MS2 tires on my 2008 edge FWD. They do not make a 235/65-17 so will a 235/70-17 fit? Need to know. thanks I wouldn't myself as the 235/70/17 is too tall for your application and although it may fit, it will throw your speedo off. I would suggest using the Michelin Cross Terrain SUV in the correct size if you want to go with Michelin. If not I would suggest looking at the Goodyear Fortera TripleTred or even the General Grabber HTS. :shades: Quote Link to comment Share on other sites More sharing options...
MARTINS Posted December 7, 2010 Author Report Share Posted December 7, 2010 On 12/7/2010 at 1:06 AM, LIVIO said: I wouldn't myself as the 235/70/17 is too tall for your application and although it may fit, it will throw your speedo off. I would suggest using the Michelin Cross Terrain SUV in the correct size if you want to go with Michelin. If not I would suggest looking at the Goodyear Fortera TripleTred or even the General Grabber HTS. :shades: Quote Link to comment Share on other sites More sharing options...
MARTINS Posted December 7, 2010 Author Report Share Posted December 7, 2010 I've checked the speedo and it has me faster than actual speed by about 4 MPH. So if it picks up son speed, I would be happy. This vehicle is terrible in snow (FWD) so after extensive research, I really want the Kuhmo SAT KL61 but is on national backorder till somtime in Jan. The Mich LTX MS2 is a close second and is readily available. So if it fits...life is great. Quote Link to comment Share on other sites More sharing options...
ablb Posted December 7, 2010 Report Share Posted December 7, 2010 On 12/7/2010 at 5:22 PM, MARTINS said: I've checked the speedo and it has me faster than actual speed by about 4 MPH. So if it picks up son speed, I would be happy. This vehicle is terrible in snow (FWD) so after extensive research, I really want the Kuhmo SAT KL61 but is on national backorder till somtime in Jan. The Mich LTX MS2 is a close second and is readily available. So if it fits...life is great. Looks like the Michelin will be 1” taller and .01” wider. The Kuhmo will turn 661 times in a mile the Mich will turn 693. There sure is a lot of difference between these tires??? Or did I pick the wrong tires? http://www.tirerack.com/tires/tires.jsp?tireMake=Kumho&tireModel=Road+Venture+SAT+KL61&partnum=365SR7KL61&vehicleSearch=false&fromCompare1=yes http://www.tirerack.com/tires/tires.jsp?tireMake=Michelin&tireModel=LTX+M%2FS2&sidewall=Blackwall&partnum=37TR7LTXMS2XL&tab=Specs ab Quote Link to comment Share on other sites More sharing options...
MARTINS Posted December 8, 2010 Author Report Share Posted December 8, 2010 On 12/7/2010 at 6:26 PM, ablb said: Looks like the Michelin will be 1” taller and .01” wider. The Kuhmo will turn 661 times in a mile the Mich will turn 693. There sure is a lot of difference between these tires??? Or did I pick the wrong tires? http://www.tirerack.com/tires/tires.jsp?tireMake=Kumho&tireModel=Road+Venture+SAT+KL61&partnum=365SR7KL61&vehicleSearch=false&fromCompare1=yes http://www.tirerack.com/tires/tires.jsp?tireMake=Michelin&tireModel=LTX+M%2FS2&sidewall=Blackwall&partnum=37TR7LTXMS2XL&tab=Specs ab Quote Link to comment Share on other sites More sharing options...
MARTINS Posted December 8, 2010 Author Report Share Posted December 8, 2010 1" over all bigger = .5 " from the hub. Does not seem very much to me. Should fit. Thanks for the reference. Most vehicles can handle 1 size larger I've been told. Will know for sure this Friday. I will post the outcome in case anyone else wants to know. Quote Link to comment Share on other sites More sharing options...
