vin number
melmoul
hi every body
where is the location of the vin number on the ford edge 2010?
Hi mel. :D Do you mean on the vehicle itself? Assuming that is what you are asking, the VIN is on a plate located on the drivers side of the dashboard, by the base of the windshield. Stand outside the vehicle by the front edge of the drivers door and look through the windshield at the area where the dash meets the base of the windshield. You will see a metal plate plate (~ 4" x 3/4") with the VIN embossed on it. Or you can look at your vehicle registration and it will be located there also. It is also located on numerous body panel stickers throughout the car, on various pieces of the paperwork you received when you purchased, etc.. However, the two simplest places to find it will be the above mentioned spots.
Hope this information helps.
Good luck. :beerchug:
Edited by bbf2530
