start car with real key
orlym2
as previousely posted by me ,i'm yet to find the place to insert the real key blade (for those with push start button) that allows you to start the engine ,after reading the quick guide manual that stated this :
Push button start
(if equipped)
Allows you to start your vehicle without a key by pressing the ENG INE START /STO P button while
pressing the brake pedal, provided your intelligent access key (IA key, if equipped) is inside the vehicle.
If necessary, you can also start your car by inserting the IA key into the back-up slot located in your
center console. Simply insert the IA key into the slot with the buttons facing you and the key ring up.
Press the brake pedal and then press the ENG INE START /STO P button to start your vehicle as
usual. You can remove the IA key from the backup slot once the vehicle is started, if desired.
