Transmission SHift Points
jkeches
Hi, everybody.
I have a 2008 SEL AWD with 30,XXX miles. The transmission seems to work OK, except when I start out briskly (half throttle or so ) it seems to go to hold the gear to about 4500 rpm and is a litle slow shifting to the next higher gear.
Normal? Anyone know of a fix?
Thanks in advance - Jim
Hi, everybody.
Someone was just talking about the 2008s getting reprogrammed. Mine would hunt for a gear then slam in like you were rear ended. I just found out that the dealer could reprogram the trans and that seemed to fix the problem and made the trans more responsive and crisp. Search around the forum
