30,000 mile service
chop73
2009 Edge Limited owner here. Just wanted to know if anyone has taken their Edge to the dealer for a 30,000 mile service. If anyone has, what did it include and how much did it cost? Thank you.
Hi chop. :D Take a look at the Scheduled Maintenance Guide you were given when you purchased your Edge (if you purchased new), and you will see what the 30,000 mile recommendations are.
If you are following the "Normal Service" recommendations, as opposed to "Severe Service" (which again, are explained in the Scheduled Maintenance Guide), there is nothing special that needs to be done at 30,000 miles. According to when you last had them done, essentially an oil/filter change, tire rotation and some various maintenance checks/inspections, most of which are usually performed in the "Multi-Point Inspection" when you have an oil change done at a Ford Dealer. That is all that Ford recommends.
Now, if you pay attention to the Dealer and their Service Department, they will sell you a bunch of other service/maintenance at 30,000 miles that is unnecessary and will do nothing but lighten your wallet. So just read the Scheduled Maintenance Guide and do what is specified there.
If you lost/misplaced your copy, you can download a PDF version here: LINK: Ford Owner Guides
Hope this information helps.
Good luck. :beerchug:
EDIT - PS - Hi chop. Two additions to the information above - First, I just checked and the 30,000 mile service also calls for and engine air filter change. Second, the Scheduled Maintenance Guide includes all Ford vehicles. So be sure you are looking at the "Normal Schedule Cars & CUV's" or the "Special Operating Conditions" sections for the same. Do not mistakenly use the "Trucks, Fullsize Vans and SUV's" section.
Edited by bbf2530
