rear view camera
Hello everyone, I got excitied when I saw the picture of SALEENS7's picture of a back-up camera installed just below the licence plate! Are there others out there who can shed more light of the part? I have the nav. system on board, so I wonder if the extra part can be integrated into the existing system...and the cost, brand of camera etc. etc. Cheers!
it is by xovision.....xovision.com. cost was $80 monitor/rear view mirror..$90 for license plate camera. i love it...picture is amazing, and when not in reverse the monitor switches back to a rear view mirror so u can see the kids in the back. hope this helps mr yuen2
Wow, thanks for the info. Saleens7. Let me get this right, your original rear-mirror is replaced with a new rear-view mirror that is also a monitor? That sounds so high tech.! Did you do the installation yourself? Sorry to throw another set of questions at you...I am just wondering if I should get it first, or consult an after-market shop in Toronto to see if they can do it...
I have been working this evening on installing a similar system. Granted I have had some beers but nothing like Jillo
Anyhow, pulled the trim, removed some of the headliner, ran the wires fairly well imo, being somewhat of a novice. Spliced the hot and ground into the rear light and went to fire up my rig. BLACK screen. Is it possible the green with red stripe wire to the reverse lamp is NOT the hot? Do you recall when you installed yours? Any help would be appreciated.
Thanks, DJ
