r20s02x Posted November 29, 2010 Report Share Posted November 29, 2010 I just drove off the lot with the 07' Edge yesterday and see that that humming noise is a very common and re-occurring problem in this vehicle. Should I just return it? I can get it fixed for free now but what if it happens again as it seems to have to so many other Edge owners? Quote Link to comment Share on other sites More sharing options...
carbonedge+ Posted November 29, 2010 Report Share Posted November 29, 2010 What humming noise? Can you give some specifics of what you bought (SE, SEL, SEL+, FWD, AWD, etc)? And any specifics about the noise? I've had an '07 SEL+ FWD since it was new but I don't recall any humming noises. Quote Link to comment Share on other sites More sharing options...
r20s02x Posted November 29, 2010 Author Report Share Posted November 29, 2010 What humming noise? Can you give some specifics of what you bought (SE, SEL, SEL+, FWD, AWD, etc)? And any specifics about the noise? I've had an '07 SEL+ FWD since it was new but I don't recall any humming noises. Well based on what I have read, it's rear bearings that will have to be replaced at least once at very low miles and again, and again...it seems to be a common problem with this model 2007 Edge SE FWD putting faulty parts or parts that are burning up these bearing. Some major leaks coming from various areas, breaks, shocks, transmissions. I just traded my 05 pontiac with 112,000 miles on it and have NEVER had a problem with it....so this concerns me...but then again looking at other make's reviews, chevy, gmc, their crossovers have cost similar problems...so I am just trying to decide if I am over reacting or if I should go pick up my trusty pontiac.... Quote Link to comment Share on other sites More sharing options...
edgedout Posted November 29, 2010 Report Share Posted November 29, 2010 Well based on what I have read, it's rear bearings that will have to be replaced at least once at very low miles and again, and again...it seems to be a common problem with this model 2007 Edge SE FWD putting faulty parts or parts that are burning up these bearing. Some major leaks coming from various areas, breaks, shocks, transmissions. I just traded my 05 pontiac with 112,000 miles on it and have NEVER had a problem with it....so this concerns me...but then again looking at other make's reviews, chevy, gmc, their crossovers have cost similar problems...so I am just trying to decide if I am over reacting or if I should go pick up my trusty pontiac.... 07 SEL+ FWD with 37,000 miles Zero problems I'm 61 yr old and this is the best car I've ever owned. Quote Link to comment Share on other sites More sharing options...
carbonedge+ Posted December 1, 2010 Report Share Posted December 1, 2010 I turned over 60k miles last week (bye bye warranty) and have had no mechanical problems like what you listed. the major leak you referenced was primarily on AWD and was a PTU issue (not present on FWD). I did experience the odd transmission jolt-like shifts early on (<10k miles) but those mysteriously disappeared and haven't happened since. Quote Link to comment Share on other sites More sharing options...
KyEdge Posted December 1, 2010 Report Share Posted December 1, 2010 I have an 07 SE with AWD and both rear bearings developed a loud whine at about 45,000 miles and were replaced under powertrain warranty. Has been quiet ever since. I now have 67,000 miles and have not experienced the PTU leak issue. Air conditioner developed a leak at about 60,000 and cost $400 to repair. Have also had a lot of squeak and rattle issues. I am now considering upgrading to a 2011 and can't decide if I want AWD or FWD. If I had it to do over, I would not have bought an 07, would've gotten a later model instead. Quote Link to comment Share on other sites More sharing options...
Steve Pala'ina Santiago Posted March 3, 2011 Report Share Posted March 3, 2011 2007 ford edge se is the champ because doesn't have a recall yet ;P Quote Link to comment Share on other sites More sharing options...
JOEHIO Posted March 4, 2011 Report Share Posted March 4, 2011 (edited) I had a rear bearing go on my '06 Explorer Limited @ 47,000 miles, thank god for the extended warranty. Service tech said it was "those damn Jap parts" ! ???? Edited March 4, 2011 by JOEHIO Quote Link to comment Share on other sites More sharing options...
rknutson Posted July 28, 2011 Report Share Posted July 28, 2011 same here 2007 se not one problem and i drive it like i stole it Quote Link to comment Share on other sites More sharing options...
07CRUSH Posted July 28, 2011 Report Share Posted July 28, 2011 same here 2007 se not one problem and i drive it like i stole it I had a 2007 sel fwd and drove it like you did and not a problem. Quote Link to comment Share on other sites More sharing options...
guscathyb Posted May 8, 2013 Report Share Posted May 8, 2013 Hi I have a 07 edge I bought used 75000 on her no issues is AWD a problem on the 07 Gus in AlA. Thank you Quote Link to comment Share on other sites More sharing options...
carbonedge+ Posted May 8, 2013 Report Share Posted May 8, 2013 Hi I have a 07 edge I bought used 75000 on her no issues is AWD a problem on the 07 Gus in AlA. Thank you There were some PTU leaking issues for the first couple years (07 being THE very first year of the Edge). If you are not noticing any leaks, you are probably okay as I would guess the original or previous owner would have gotten that fixed. What color is your Edge? You could be in an elite group... My 07 is FWD and just passed 115k miles. Quote Link to comment Share on other sites More sharing options...
Feirstein Posted May 8, 2013 Report Share Posted May 8, 2013 Only other significant issue in 07 was a poorly designed power brake booster. Ford redesigned the part several times and it is all good now, but never put into place a recall, or customer satisfaction program. Quote Link to comment Share on other sites More sharing options...
guscathyb Posted May 9, 2013 Report Share Posted May 9, 2013 Thanks for reply carbonedge+feirstein its color is very light cream with light cream interior light brown trim.Will the brake booster from later years fit the 07 Thanks again yall for the info. Now the wife rather drive the 07edge over the 11mustang .Can we say 2014 edge sport just saying. Quote Link to comment Share on other sites More sharing options...
guscathyb Posted May 9, 2013 Report Share Posted May 9, 2013 yes you are right carbonedge+ the previous owner did replace them at 45000. Will I need to replace them again is this a major job and expensive ? Yhanks Yall Quote Link to comment Share on other sites More sharing options...
carbonedge+ Posted May 9, 2013 Report Share Posted May 9, 2013 yes you are right carbonedge+ the previous owner did replace them at 45000. Will I need to replace them again is this a major job and expensive ? Yhanks Yall I would hope it is a once and done repair. I have no idea as to the extent of labor or cost should it have to be repaired again (mine is FWD so it was not anything I had to deal with). Some others on here may have more to contribute in relation to that question. I've had no issues with the brake booster either. Enjoy it! Quote Link to comment Share on other sites More sharing options...
