View Tire Pressure
jsabia85
IS it possible to view the tire pressure on a 2011 Ford Edge Limited in the instrument cluster? Or does the tire pressure info only come up when there is low tire pressure?
I have had my Limited for about two weeks, and I don't believe it will show you the pressures unless there is an issue, and then I don't think it will tell you which tire has the issue. It works this way also on my wifes VW Eos.
I still have my 2008 Acadia and waiting fior delivery of a new 2011 Edge Limited
The Acadia shows pressures of each tire but as L1Tech suggests you have to reset each tire individually after rotation
Hoping my new Edge will have this feature, it is very useful
