Toff46 Posted November 23, 2010 Report Share Posted November 23, 2010 I'm driving the Ford Edge SEL 2011 on loan for now 2 days - Originally I was very excited about this opportunity since I considered buiyng the Sport one mid 2011. But after 2 days I can help but noticing the following interior problems: - The front seat head rest is way too canted and you can't remove it and turn it around - The aluminun trim cornering the mid consol is killing my right knee - Shifting down in Drive has to be done carefully to not end up in Manual - They got rid of that phone and wallet spot I like so much in the older version It is a great crossover and I love driving it and if someone had a solution for the headrest I would buy it. Quote Link to comment Share on other sites More sharing options...
Bookworm Posted November 25, 2010 Report Share Posted November 25, 2010 I'm driving the Ford Edge SEL 2011 on loan for now 2 days - Originally I was very excited about this opportunity since I considered buiyng the Sport one mid 2011. But after 2 days I can help but noticing the following interior problems: - The front seat head rest is way too canted and you can't remove it and turn it around - The aluminun trim cornering the mid consol is killing my right knee - Shifting down in Drive has to be done carefully to not end up in Manual - They got rid of that phone and wallet spot I like so much in the older version It is a great crossover and I love driving it and if someone had a solution for the headrest I would buy it. Regarding the headrest, I didn't like it either at first but found that if I moved it to a higher position so that my head hit it towards the bottom of the headrest it was much easier to deal with. I'm 6'4" , btw. Quote Link to comment Share on other sites More sharing options...
wilsons66604 Posted November 25, 2010 Report Share Posted November 25, 2010 Regarding the headrest, I didn't like it either at first but found that if I moved it to a higher position so that my head hit it towards the bottom of the headrest it was much easier to deal with. I'm 6'4" , btw. I think the head rest can be removed. You just need to stick an allen wrench into a hole to release it. Quote Link to comment Share on other sites More sharing options...
Toff46 Posted November 26, 2010 Author Report Share Posted November 26, 2010 Regarding the headrest, I didn't like it either at first but found that if I moved it to a higher position so that my head hit it towards the bottom of the headrest it was much easier to deal with. I'm 6'4" , btw. Yes the rear headrest can be removed with an allen wrench or anything strong and small enough to fit in that hole so that you can push on the release. (crazy system - maybe Ford wanted to prevent kids from removing the headrest when we're driving...) for the driver and passenger side headrest you need to push on the protuding button located at he Right base (if seated you twist around) and at the same time depress the flushed button on the Left base and push up the all headrest. (I tried all that yesterday afternoon). Now I have to find head rest less canted that fit in these seats... Quote Link to comment Share on other sites More sharing options...
AXCL Posted November 26, 2010 Report Share Posted November 26, 2010 - Shifting down in Drive has to be done carefully to not end up in Manual You don't have to worry about this on the 11' Sport. Manual shifting isn't on the stick, its paddle shifters on the wheel. Quote Link to comment Share on other sites More sharing options...
MrHappy Posted November 27, 2010 Report Share Posted November 27, 2010 You don't have to worry about this on the 11' Sport. Manual shifting isn't on the stick, its paddle shifters on the wheel. Think they mean on the stick, since M is below D if you're used to D being at the bottom. (Rather than D at the bottom then left/right into manual mode like other vehicles) Quote Link to comment Share on other sites More sharing options...
emeraldtx Posted December 3, 2010 Report Share Posted December 3, 2010 - The front seat head rest is way too canted and you can't remove it and turn it around It is a great crossover and I love driving it and if someone had a solution for the headrest I would buy it. One of the VERY first things I did when I got my Edge was flip the headrest. I wear a high ponytail most of the time, and it just wasn't working for me. Saw the posts tonight about the Allen wrench, but maybe that's just for the back headrests, as mine came out & flipped fairly easily with just the button (both driver & passenger in front). Only downside is the pretty stitching isn't on the backside, which is now the frontside. Small thing to give up for ponytail freedom! :D Quote Link to comment Share on other sites More sharing options...
samskudd Posted December 3, 2010 Report Share Posted December 3, 2010 One of the VERY first things I did when I got my Edge was flip the headrest. I wear a high ponytail most of the time, and it just wasn't working for me. Saw the posts tonight about the Allen wrench, but maybe that's just for the back headrests, as mine came out & flipped fairly easily with just the button (both driver & passenger in front). Only downside is the pretty stitching isn't on the backside, which is now the frontside. Small thing to give up for ponytail freedom! :D You know that headrest is designed that way for whiplash protection, right? Reversing the headrest puts it way too far from your head. Turning it around is not good in a rear crash...but it is easy to turn around as stated up above. Other vehicles headrests MAY fit in there as well (mustang, fusion, etc) Quote Link to comment Share on other sites More sharing options...
On the edge Posted December 20, 2010 Report Share Posted December 20, 2010 Response from the NHTSA regarding the headrests from hell: We have found that some manufacturers have placed the head restraint much closer to the head than the 55 mm that the upgraded standard requires. We have been told specifically by Ford that the IIHS ratings are forcing them to put head restraints closer than they need to for our new standard and for safety. They do this knowing that it will alienate a small segment of their customers, but they will gain customers if they get a high rating from IIHS. In a presentation last year at a Society of Automotive Engineers (SAE) conference, Ford stated that, in order to get a good IIHS rating, the backset value they must design to for the Ford Edge is just 2 mm. This is much closer to then the 55 mm required by our standard. Quote Link to comment Share on other sites More sharing options...
emeraldtx Posted December 20, 2010 Report Share Posted December 20, 2010 You know that headrest is designed that way for whiplash protection, right? Reversing the headrest puts it way too far from your head. Slow response, as I just saw this. yep, I'm very aware that's what it is for. I also know that I can't/won't drive with my neck bent forward in a ridiculous position. Flipping the headrest results in it being in almost the exact spot that my old Camry was (as in distance-from-my-head). I'm not feeling unsafe at all... but thanks for your concern! Quote Link to comment Share on other sites More sharing options...
wilsons66604 Posted December 21, 2010 Report Share Posted December 21, 2010 Slow response, as I just saw this. yep, I'm very aware that's what it is for. I also know that I can't/won't drive with my neck bent forward in a ridiculous position. Flipping the headrest results in it being in almost the exact spot that my old Camry was (as in distance-from-my-head). I'm not feeling unsafe at all... but thanks for your concern! By raising my headrest all the way to the top notch, it prevents it from bugging me. Quote Link to comment Share on other sites More sharing options...
akirby Posted December 21, 2010 Report Share Posted December 21, 2010 By raising my headrest all the way to the top notch, it prevents it from bugging me. According to the NHTSA the reason Ford's headrests are so far forward is not because of NHTSA requirements but due to the more stringent IIHS whiplash tests. Quote Link to comment Share on other sites More sharing options...
robertorx Posted January 6, 2011 Report Share Posted January 6, 2011 I lost a lot of storage going from an '08 edge to an '11. Cupholders are smaller, door cupholders are almost non-existent, center console tray is less convenient (but the center stack looks nicer), shelf/tray on top of dash is gone, little storage on interior door pulls is gone, and the tray inside the center console is smaller. It's not that big of a deal just need to get used to it, at least it was to make the interior more attractive. Quote Link to comment Share on other sites More sharing options...
wilsons66604 Posted January 6, 2011 Report Share Posted January 6, 2011 I lost a lot of storage going from an '08 edge to an '11. Cupholders are smaller, door cupholders are almost non-existent, center console tray is less convenient (but the center stack looks nicer), shelf/tray on top of dash is gone, little storage on interior door pulls is gone, and the tray inside the center console is smaller. It's not that big of a deal just need to get used to it, at least it was to make the interior more attractive. I noticed the lack of places to put my stuff right away. The under arm console is huge but a I would like a better tray that fits in it. The coin tray is a joke. Quote Link to comment Share on other sites More sharing options...
11Sport Posted January 6, 2011 Report Share Posted January 6, 2011 I would love it if I could lower the steering wheel about an inch lower. Its feels so much higher then any other vehicle I have driven. It feels to thin too. Our Escape has a thicher steering wheels. Quote Link to comment Share on other sites More sharing options...
choff1138 Posted January 6, 2011 Report Share Posted January 6, 2011 I would love it if I could lower the steering wheel about an inch lower. Its feels so much higher then any other vehicle I have driven. It feels to thin too. Our Escape has a thicher steering wheels. The steering wheel on the Limited is very adjustable - is it not on the sport? Quote Link to comment Share on other sites More sharing options...
11Sport Posted January 6, 2011 Report Share Posted January 6, 2011 The steering wheel on the Limited is very adjustable - is it not on the sport? Its the same as the limited. Quote Link to comment Share on other sites More sharing options...
choff1138 Posted January 6, 2011 Report Share Posted January 6, 2011 Its the same as the limited. Ok - I know it took almost a month for my husband and I to find a spot that worked for both of us so we didn't have to adjust it each time we were going somewhere. A long trip I would change it some, but for shorter trips we found a good spot. Quote Link to comment Share on other sites More sharing options...
wilsons66604 Posted January 7, 2011 Report Share Posted January 7, 2011 I am the only driver so I have the pre set 1 for everyday and pre set 2 for highway driving (reclined :-) Too bad the steering wheel isn't power adjusted. Quote Link to comment Share on other sites More sharing options...
