cnsteve Posted November 22, 2010 Report Share Posted November 22, 2010 I have an '09 Edge with the DATC. When I lower the display temperature, it jumps from 19C to 16C. There is NO 18 nor 17 degree on the display. That would be a three degree F jump. There doesn't seem to be any difference whether its on auto, defrost, ect. Does this happen with everyone else's '09 or should i start to call the dealership? Thanks Stever ps. I have scoured the manual and searched the forum. No mention. Quote Link to comment Share on other sites More sharing options...
bbf2530 Posted November 22, 2010 Report Share Posted November 22, 2010 I have an '09 Edge with the DATC. When I lower the display temperature, it jumps from 19C to 16C. There is NO 18 nor 17 degree on the display. That would be a three degree F jump. There doesn't seem to be any difference whether its on auto, defrost, ect. Does this happen with everyone else's '09 or should i start to call the dealership? Thanks Stever ps. I have scoured the manual and searched the forum. No mention. Hi Stever. :D No need to call the Dealership, your DATC system is working correctly. If you have the system set to Fahrenheit, the gap is 60 to 65 and vice-a-versa (no 61, 62, 63 or 64*F). Without getting into too much useless detail, when set to 60*F (or 16*C), it is somewhat equivalent to setting the system to "MAX AIR" on a manual system, and that is the way the system is designed. Good luck. :beerchug: Quote Link to comment Share on other sites More sharing options...
