Ford Edge: Specifications
Edge Guide
TECHNICAL SPECIFICATIONS
V-6
BODY
Construction: Unibody
Final Assembly Location: Oakville , Ontario. Canada.
POWERTRAIN AND CHASSIS
ENGINE
3.5L DOHC 24-valve V6
Manufacturing Location: Lima Engine Plant, Ohio
Configuration: 60 degree V6, aluminum block and heads
Intake Manifold: Composite, split plenum
Exhaust Manifold: Cast Iron
Crankshaft: Forged steel
Redline: 6700 RPM
Idle Speed in Drive: 620 RPM (640 with trailer tow package)
Throttle Body: 65mm, electronic
Valvetrain: DAMB, 4 valves per cylinder, intake variable camshaft timing
Valve Diameter: Intake: 37mm; Exhaust: 31mm
Pistons: High temperature cast aluminum alloy with low-friction coated skirts, low tension rings
Connecting Rods: Cracked powder metal
Ignition: Pencil Coil
Bore x stroke: 3.6 x 3.4 in/ 92.5 x 86.7 mm
Displacement: 213 cu in/ 3.496 cc
Compression ratio: 10.3:1
Horsepower: 265@ 6250
Horsepower per liter: 71.5
Torque: 250 lb-ft @ 4500
Recommended fuel: 87 Octane
Fuel capacity: 20 gallons
Fuel Injection: Sequential multi-port fuel injection
Oil Capacity: 5.5 quarts, with filter
Recommended Oil: GF4, 5W-20
DRIVETRAIN
Layout: FWD (Optional AWD)
TRANSMISSION
Standard: 6-Speed Automatic
Gear Ratios
1st: 4.484
2nd: 2.872
3rd: 1.842
4th: 1.414
5th: 1.000
6th: 0.742
REV: -2.882
Final Drive: FWD: 2.77; AWD: 3.16
SUSPENSION
Front: Macpherson strut and L-shaped lower control arm with isolated subframe and stabilizer bar
Rear: Independent suspension with trailing blade, integrated knuckle and lateral links, isolated subframe and stabilizer bar
STEERING
Type:Power rack and pinion
Steering column: Tilt-telescope
Ratio: 17.7:1
Turns lock-to-lock: 3.1
Turning circle curb-to-curb: 11.74 m (38.6 ft)
BRAKES
Type: 4-wheel ABS (4 channel); Optional AdvanceTrac® with Roll Stability Control (RSC®)
Front: Disc
Swept area: FWD (63.1 in 2) AWD (69.79 in 2)
Rear: Disc
Swept area: 50.38 in 2
Power assist: Yes
TIRES AND WHEELS
P235/65R17 all-season BSW on 17x7-in. steel with cover (SE)
P235/65R17 all-season BSW on 17x7.5-in. painted aluminum (SEL, optional SE)
P245/60R18 all-season BSW on 18x7.5-in. painted aluminum or aluminum with chrome (optional SEL)
Recommended tire pressure (front/rear): 35 psi
DIMENSIONS (inches unless otherwise noted) (All dimensions are Preliminary)
EXTERIOR
Wheelbase: 111.2
Overall length: 185.7
Overall width: 75.8 excluding mirrors 87.1 including mirrors
Overall height: 67.2 (w/o roofrack); 68.9 (w/roofrack)
Track width, front/rear: 65.1/64.9
Ground clearance: 8.0
Approach angle: 16 deg
Departure angle: 24.5 deg
Ramp breakover angle: 17.3 deg
Cargo Volume behind front row: 69.6 cu ft
Cargo Volume behind second row: 32.1 cu ft
INTERIOR
Seating capacity: 5 passenger
Headroom
Front row: 40.0 (w/o moonroof); 37.8 (w/moonroof)
Second row: 39.3 (w/o moonroof); 38.7 (w/moonroof)
Legroom
Front row: 40.7
Second row: 39.6
Shoulder room
Front row: 58.9
Second row: 58.8
Hip room
Front row: 54.8
Second row: 56.3
WEIGHTS AND CAPACITIES (pounds unless otherwise noted)
Maximum towing capacity
(when properly equipped)
Class II (3500 lbs)
Maximum payload (when properly equipped) including 150 lb driver
FWD: 1077; AWD: 1058
Base curb weight
FWD: 4073
AWD: 4282
Weight distribution (f/r)
60/40
MAJOR STANDARD EQUIPMENT
SE Model
AdvanceTrac® with Roll Stability Control™, spoiler, remote keyless entry, manual fold power mirrors, cloth bucket seats, 2nd row 60/40 split-fold-flat bench seats with center head restraint, Side air bags, Safety Canopy™, 3-point belts in all positions, front row height adjustable seat belts, BeltMinder® (front row), Personal Safety System™, child safety locks, LATCH, front and rear floormats, front console, manual air conditioning, power windows with one-touch down driver, power locks, speed control, premium AM/FM/Single CD/MP3 capable audio system and 4 speakers
SEL adds
Fog lamps, 6-way power driver seat, overhead console, premium CDx6 with 9 speakers, steering wheel audio controls, unique Interior treatments, message center/compass, chrome exhaust tips, dual illuminated visors
OPTIONS
Interior
auto-dimming rearview mirror, premium CDx6, audio jack in center console, SIRIUS Satellite radio, rear cargo management system.
SEL only options: Leather seats, 6-way power passenger seat, passenger seat fold flat, heated seats, memory driver seat, remote release on 2nd row fold-flat seats, dual electronic automatic temperature control with air filter, manual fold power heated side mirrors with puddle lamps and memory, audiophile sound, DVD entertainment system, navigation system, redundant climate controls on steering wheel
Exterior
AWD, , Class II trailer tow package, automatic headlamps, roof side rails, 17" painted aluminum wheels, keyless entry pad
SEL only Options: Panoramic Vista Roof™, Reverse Sensing System, 18" chrome clad or painted aluminum wheels
OTHER
Exterior color
Blazing Copper, Crème Brulee, Redfire, Black Clearcoat, Carbon, Dune Pearl, Pewter, Light Sage, Dark Amethyst
Interior trim
Medium Light Stone, Camel, Charcoal Black
WARRANTY INFORMATION
5-year, 60,000 bumper-to-bumper warranty
