2011 Edge/MKX hub size
bhazard1
Same for me here.
I bought a set of "hub centric"/OEM Macpek 17in steel wheels (ref. X42756) to use as winter rims on my Ford Edge 2011, and it turned out the center hole diameter on the wheels is 70mm+... a little bit wider that the hubs on the car that are 63mm and change. What a disappointment!
The only explanation that I can see is that the 2007 to 2010 Edge models had 70mm+ hub diameters, and that Ford changed it for the 2011. Macpek "assumed" to quickly the 2011 was identical to previous models... hence the problem.
I've complained to both Macpek and the reseller and I look forward to their response :angry:. I've paid the extra cash to get OEM wheels. Had I known they were not true OEMs I would have gone for the basic multi-fit ones...
Emmdl
Ford Edge 2011 SEL
Aurora, Ontario
I've been able to come up with 63.36mm. My dealership couldn't find it in any specs, so we measured it with a caliper to be 63.29mm, but looking for hub rings showed 63.36mm as the closest option. The best I could get was actually 63.9, which are very slightly too big (around .5 mm), so I think that validates the 63.36mm. If not, its certainly within .25mm and isn't a hub size listed for anything else I could find.
  • 11 months later...
Did you ever resolve this and if so what adapter rings did you use
