Sythentic or Regular oil?
Garemz
Hi,
I live in Edmonton, Alberta Canada, those who know of the place, know that the Winters here are bone chilling Cold it get's past -30C at times.
What would be the better choice to use for Oil, Synthetic? or Regular Oil?
Cheers
Edited by Garemz
All oils have come a long way with the use of additives but i was informed a few years back. By a chemist that the properties inherent in synthetic oils make them far superior to standard oils in the way they handle temperature extremes. I made the choice years ago to use full synthetic oils in all my vehicles. Search Google, do some reading and see what you think.
Hi,
Cheers
Definitely synthetic - it will flow better at those extremes. Ford synthetic 5W-20 should work fine. If you can find a 0-W20 that meets the Ford spec in the owner's manual that would probably work even better.
FYI - the Ford factory oil is a synthetic blend which is better than regular dino oil.
Edited by akirby
