need help with offset question
mjd1001
We are going to be getting in our new edge, and I have a question that I haven't had luck with researching..hopefully someone here can help.
For the new 2011 Ford Edge, will newer Mustang wheels fit? They have the same bolt pattern, but I know the wheels from the Mustang I'd have access to are 19 inches and have a +50mm offset.
I know most Edge wheels offsets are +35 to +45...just wondering if anyone knows of any fitment issues when trying to use Mustang wheels, or if the +50mm offset will cause bearign damage eventually.
Anyone with any information on this...I'd really appreciate it!
Higher offset should sit in father on the wheelwell. Definately not hurt wheelbearings. Better for them I guess. More the wheels sticks out puts more stress on the wheel bearings. Also, I am unsure on the hub diameter of the edge vs mustang. I would assume they would fit but not sure how they would look sitting farther under the fenders. I am sure sombody will chime in that would have the answers you are looking for.
