BrentMKXElite Posted October 25, 2010 Report Share Posted October 25, 2010 I have an 07 MKX and I'm wanting to re-grease the moonroof tracks due to some noise Im receiving just prior to a complete close. It sounds like some friction/vibration is in the track. My question is, does anyone know the type of factory grease that is used in these MKX/Edge moonroofs. I understand improper grease is BAD. So I want to make sure I use the correct spec. Any help would be great. Thanks. Quote Link to comment Share on other sites More sharing options...
07CRUSH Posted October 25, 2010 Report Share Posted October 25, 2010 I have an 07 MKX and I'm wanting to re-grease the moonroof tracks due to some noise Im receiving just prior to a complete close. It sounds like some friction/vibration is in the track. My question is, does anyone know the type of factory grease that is used in these MKX/Edge moonroofs. I understand improper grease is BAD. So I want to make sure I use the correct spec. Any help would be great. Thanks. use a dry lube ,it works best Quote Link to comment Share on other sites More sharing options...
chops65 Posted September 22, 2011 Report Share Posted September 22, 2011 I have an 07 MKX and I'm wanting to re-grease the moonroof tracks due to some noise Im receiving just prior to a complete close. It sounds like some friction/vibration is in the track. My question is, does anyone know the type of factory grease that is used in these MKX/Edge moonroofs. I understand improper grease is BAD. So I want to make sure I use the correct spec. Any help would be great. Thanks. Lithium grease is great. It doesn't damage the plastic in the BAMR Quote Link to comment Share on other sites More sharing options...
