msemple Posted May 11, 2007 Report Share Posted May 11, 2007 Everyone, We have been noticing a noise when you put into drive from park. It seems to be a plastic cruching noise. Does anyone else seem to be having this issue? Mike Quote Link to comment Share on other sites More sharing options...
SALEENS7 Posted May 11, 2007 Report Share Posted May 11, 2007 (edited) Everyone,We have been noticing a noise when you put into drive from park. It seems to be a plastic cruching noise. Does anyone else seem to be having this issue? Mike Hey Mike, I have the same noise...but i am sure it is the transmission unlock, if you can call it that. The Edge cannot go into gear with out you pressing on the brake, and i believe inside the shifter there is a lock/unlock feature....i am not an expert at this...but i had this same thing on my mustang.....it sounds like a plastic crunch but is actually the shifter unlocking to go into gear......your dealer will probably soothe your mind better than my explananton just did though. Good luck. Also i have noticed with the transmission on these Edges..when you place it in park, the car will move back about an inch or so..i have noticed that when i park on a slight incline, put it in park, it will jump back ever so slightly...1-2 ". Edited May 11, 2007 by SALEENS7 Quote Link to comment Share on other sites More sharing options...
Ksaness07Edge Posted May 11, 2007 Report Share Posted May 11, 2007 I haven't noticed a crunch but I did have a squeak so when I brought it in for the first service I mentioned it and haven't noticed anything since Quote Link to comment Share on other sites More sharing options...
pbmitch Posted June 30, 2007 Report Share Posted June 30, 2007 Everyone,We have been noticing a noise when you put into drive from park. It seems to be a plastic cruching noise. Does anyone else seem to be having this issue? Mike I had the same noise with my shifter. I took it in to the dealer and they said it was not normal. They ordered me a new shifter assembly and they installed with no problem. Noise is gone and the shifter feels more solid now. Go talk to your service dept. Quote Link to comment Share on other sites More sharing options...
