securinu Posted May 9, 2007 Report Share Posted May 9, 2007 This is an install from start to finish 1 Quote Link to comment Share on other sites More sharing options...
DJ Starr Posted May 9, 2007 Report Share Posted May 9, 2007 Very very nice.... Safe to say it was significantly LESS than the factory option with MORE functionality? Quote Link to comment Share on other sites More sharing options...
Houndkeeper Posted May 9, 2007 Report Share Posted May 9, 2007 That is an awsome record of what you did Securinu! Nice job and it looks greeeat! How long did that take? Quote Link to comment Share on other sites More sharing options...
Ksaness07Edge Posted May 9, 2007 Report Share Posted May 9, 2007 with that unit do you keep the factory steering wheel controls? Quote Link to comment Share on other sites More sharing options...
securinu Posted May 10, 2007 Author Report Share Posted May 10, 2007 Yes way less expensive with way more oprions. They take about 2 hours to do Yes you retain the steering wheel control Quote Link to comment Share on other sites More sharing options...
RayoVac Posted May 10, 2007 Report Share Posted May 10, 2007 securinu said: Yes way less expensive with way more oprions. They take about 2 hours to do Yes you retain the steering wheel control If you already have the audiophile system with sub woofer, can you easily utilize the factory sub? What about amps, do you know if the Audiophile uses any kind of external amp for the sub, or is it all in the head? And if so, how hard is it to get output from one of the Pioneers to the sub? Thanks in advance, Rayo Quote Link to comment Share on other sites More sharing options...
securinu Posted May 10, 2007 Author Report Share Posted May 10, 2007 RayoVac said: If you already have the audiophile system with sub woofer, can you easily utilize the factory sub? What about amps, do you know if the Audiophile uses any kind of external amp for the sub, or is it all in the head? And if so, how hard is it to get output from one of the Pioneers to the sub? Thanks in advance, Rayo It has a seperate amp and there is an adapter to plug in to that harness on the back of the radio. Quote Link to comment Share on other sites More sharing options...
xplorgee Posted May 13, 2007 Report Share Posted May 13, 2007 Can it utilize the stock sirus antenna? Quote Link to comment Share on other sites More sharing options...
SALEENS7 Posted May 13, 2007 Report Share Posted May 13, 2007 securinu said: This is an install from start to finishOutstanding writeup/photo documention....... Quote Link to comment Share on other sites More sharing options...
xplorgee Posted May 15, 2007 Report Share Posted May 15, 2007 What kind of parts do you need to get this install setup. it doesnt seem like you need much. Receiver harness splicers and resistor ( what kind ) to keep stock wheel controls different crimpers brackets or mounting kit options speakers siruis or xm receiver ipod cable is there anything that can be taken out or added to this list. I would really like to do this but know know 100 percent of what i need. I hate going back to the store for something I forgot. Quote Link to comment Share on other sites More sharing options...
securinu Posted May 16, 2007 Author Report Share Posted May 16, 2007 Well we have sold a one to someone i here i think . He bought a Avic D3 ipod cable and xm navtraffic with steering wheel control. You also need a dash kit a wire harness and antenna adapter . We can wire it all except for the park brake and vss if you want to do something like that and also install the deck into the kit we do that all the time for other customers then all you need to do is pop off the dash and tap 2 wires . Quote Link to comment Share on other sites More sharing options...
ike Posted May 16, 2007 Report Share Posted May 16, 2007 securinu said: We can wire it all except for the park brake and vss if you want to do something like that and also install the deck into the kit we do that all the time for other customers then all you need to do is pop off the dash and tap 2 wires . I assume VSS = Vehicle Speed Sensor ? Can you tell us how to find this wire to tap ? This apparently makes the Pioneer AVIC D3 much more accurate for navigation. Quote Link to comment Share on other sites More sharing options...
xplorgee Posted May 18, 2007 Report Share Posted May 18, 2007 Does anybody know if the sensors in the rear for backing up are connected to the stereo or are the part of a different system? Quote Link to comment Share on other sites More sharing options...
BlueLtd Posted May 18, 2007 Report Share Posted May 18, 2007 xplorgee said: Does anybody know if the sensors in the rear for backing up are connected to the stereo or are the part of a different system? The parking aid has its on module and speaker located in the left rear panel. Quote Link to comment Share on other sites More sharing options...
xplorgee Posted May 18, 2007 Report Share Posted May 18, 2007 Thanks. I guess all need to do is figure out how to setp the steering wheel controls and find out how to bypass the nav/dvd deal while the car is mooving. Its not for me, but for the passenger rider. Quote Link to comment Share on other sites More sharing options...
ike Posted May 18, 2007 Report Share Posted May 18, 2007 xplorgee said: ...and find out how to bypass the nav/dvd deal while the car is mooving. Its not for me, but for the passenger rider. I would think all you need to do is put a switch in for the parking brake wire (instead of connecting it to the parking brake) from the Navigation unit. When the switch was "on", it would think you are stopped and it would allow you to input whatever you wanted. When you're done, hit the switch again and it'll think you're moving. Quote Link to comment Share on other sites More sharing options...
xplorgee Posted May 19, 2007 Report Share Posted May 19, 2007 I found out on the AVIC-D3, you move the yellow wire on the white connector from the bottom to the top. You then ground the light green wire on the black harness and the yellow wire you just moved. Thats about it. I head it works from AVIC411.com. How hard is it to remove the front panel of the stereo? How is it done. I think its one piece. Where should I start pulling from? Quote Link to comment Share on other sites More sharing options...
xplorgee Posted May 19, 2007 Report Share Posted May 19, 2007 Also, where is the stock sirus wire run? Is it on the driver side or passenger bottom rail? Quote Link to comment Share on other sites More sharing options...
ike Posted May 19, 2007 Report Share Posted May 19, 2007 AVIC411.com GREAT Site !!! Thanks for posting. Very helpful. Quote Link to comment Share on other sites More sharing options...
logman Posted May 21, 2007 Report Share Posted May 21, 2007 (edited) securinu said: It has a seperate amp and there is an adapter to plug in to that harness on the back of the radio. I have a Fusion and I want to hook up the roof mounted antenna to the factory radio. I have the factory/dealer installed unit. However, their audio folks put in the small Sirius antenna. Shouldn't you be able to use the roof mount antenna as it says in the owners manual? Any help in this matter is greatly appreciate because I keep getting the run around from all concerned. Edited May 21, 2007 by logman Quote Link to comment Share on other sites More sharing options...
xplorgee Posted May 23, 2007 Report Share Posted May 23, 2007 I had the stock sirus antenna and they used it with my pioneer sirus reciever. So far it works great. Ive heard of it picking up XM also???? Quote Link to comment Share on other sites More sharing options...
firewolff Posted May 25, 2007 Report Share Posted May 25, 2007 xplorgee said: Also, where is the stock sirus wire run? Is it on the driver side or passenger bottom rail? The complete sirius unit is located in the back of the vehicle open the hatsch pull the plastic entrance plate off and look down its mounted on the drivers side undo the two bolts unplug it your ready to upgrade to an aftermarket. the plastic cover on the antenna can be removed to use with your unit although my reception is not as strong as it was with actual pioneer ant. but I didnt want extra stuff all over the roof. Quote Link to comment Share on other sites More sharing options...
xplorgee Posted May 25, 2007 Report Share Posted May 25, 2007 I found out about the sirius receiver. i wonder if they have to resplice a new connector when I get my Hybrid Edge in a few years. How hard is it to remove the front bezel for the stereo. Im thinking about doing a bazooka tube and a amp. I dont think im going to do the amp for the speakers. I just had polk 6x8s installed and they sound great with the AVIC - D3 built in amp. Before I get distortion, my doors rattle for some reason. Car is still quiet on the highway with the radio off. Quote Link to comment Share on other sites More sharing options...
SUMrTOY Posted July 5, 2007 Report Share Posted July 5, 2007 Am I blind, because I don't see a writeup? Install looks awesome though and retaining the wheel controls is pretty essential IMO. Wheel controls has always prevented me from installing an aftermarket head unit in the past. So you were able to retain steering wheel control... But you used an aftermarket sirius tuner? Quote Link to comment Share on other sites More sharing options...
xplorgee Posted July 6, 2007 Report Share Posted July 6, 2007 Check out the write up from Ike. Its great. I have an AVIC D3 and spent about a grand on it with install. You need you AVIC, wire harness ( i think the one from the new explorers work), steering wheel controller converter (70 bucks) and your tools. Its about a 2 hour deal unless you have programmed your steering control deal before. Quote Link to comment Share on other sites More sharing options...
