Owner's Guide v1 vs v2
revOevoM
Edit: This comparison is bewteen versions 1 and 2 of the MyFordTouch Supplement, not the Owner's Guide. Geez, I titled the topic incorrectly. I'll try to get a similar compare done for the Owner's Guide this week.
I did my best to determine the following differences. Some may have been overlooked. But I think I got the major stuff. v1 dated May 2010; v2 dated September 2010
Aside from the obvious page numbers (some due to new page breaks, some by text), a few typos corrected and a couple "Press"s changed to "Touch"s, here's the list:
p5 v1
Note: The full corner display (2) with preselected shortcuts is the default home screen. This screen will momentarily appear at vehicle start up and will then transition to your chosen selection, if different.
p5 v2
Note: The full corner display (2) with preselected shortcuts is the default home screen. This screen will appear at vehicle start-up.
p7 v2
[added] • (Hazard flasher): Touch to activate/deactivate the hazard flashers. When you are using the touchscreen system, be careful not to accidently activate the hazard flashers. For more information, refer to Hazard Flasher Control in the Roadside Emergencies chapter in your Owner Guide.
p16 v2
all references to "Audio Visualizer (if equipped)" have been deleted
p16 v1
HD Radio On/Off (if equipped): HD Radio technology enables you to receive radio broadcasts digitally, (where available), providing free, crystal clear sound. Refer to the HD Radio information in the following section.
p16 v2
• Press the HD Radio button to activate HD Radio technology. This feature enables you to receive radio broadcasts digitally, (where available), providing free, crystal clear sound. Refer to the HD Radio information in the following section.
p18 v1
HD Radio™ information (if equipped, U.S. only)
Note: When this logo is available, you will also see Title and Artist fields on screen.
[deleted] To access, press the lower left corner of the touchscreen. Then, press AM/FM > Options > HD Radio > On.
p 18 v2
HD Radio™ information (if available)
Note: When this logo is available, you may also see Title and Artist fields on screen.
[added] Note: HD Radio broadcasts are not available in all markets.
p19 v1
The tagging feature allows you to tag a song to download later. When you are on an acquired HD Radio station, the TAG button will become available (provided the feature has been turned on. To turn on, press AM/FM > Options > TAG On).
When you are listening to a song you would like to tag to download later, simply press the TAG button.
p19 v2
The tagging feature allows you to tag a song to download later. When you are on an acquired HD Radio station, the TAG button will become available (provided the feature has been turned on). To use the tag feature:
1. Press AM/FM > Options > TAG On.
2. When you hear a song you like, touch TAG.
p22 v1
• Press the SIRIUS button repeatedly to change SIRIUS presets (SIRIUS 1, 2 or 3).
p22 v2
• Press the SIRIUS button repeatedly to change SIRIUS modes (SIRIUS 1, 2 or 3).
p24 v1
**Note: If you have said, " Sports Game", you may say any of the following commands:
p24 v2
** Late availability (if equipped): If you have said, " Sports Game", you may say any of the following commands:
p29 v1
• Autoplay on/off: With this feature on, you can listen to music which has already been randomly indexed during the indexing process. With this feature off, the system will not begin to play any of your music until all the media has been indexed and you make a selection.
p31 v2
• Autoplay on/off: With this feature on, the system will automatically switch to the media source upon intial connection and you can listen to music which has already been randomly indexed during the indexing process. With this feature off, the system will not automatically switch to the inserted media source.
p30 v1
• Media Device Information: Displays descriptive information about the device, if connected.
p31 v2
• Media Device Information: Displays descriptive information about the device, if connected and available.
p32 v2
[added] a new picture for "To view song information..."
[added] To view your album art in a 3D carousel: Press Browse > Music > Albums > Cover Art. If the Gracenote cover art feature (covered in the previous section) is turned on, you will be able to touch and drag the screen with your finger to view your album art. Tap on an album to select.
[added] In order to playback video from your iPod/iPhone (if compatible), you MUST have a special combination USB/RCA composite
video cable (available for purchase from Apple). Once the cable is connected to your iPod/iPhone, plug in the other end into both the RCA jacks and the USB port.
p40 v2
[added] Note: Certain smart phones may support transferring street addresses when listed with phone book contact information. If this feature is supported, you can then select and use these addresses as destinations and also save them as favorites.
p43 v2
[added messaging text] • Do not disturb: Select to have all calls go directly to your voice mail and not ring in the vehicle cabin. Note: With this feature turned on, text message notifications are also suppressed and will not ring inside the cabin.
[deleted] references to "DUN (dial up network)"
[deleted] • Birthday reminders: Select to have the system remind you of important birthdays. When the notification arrives, you can also choose to send a message.
p47 v1
Note: In order to allow a break-in period for your vehicle, you will not be able to create a Vehicle Health Report until your vehicle odometer has reached 100 miles.
p48 v2
Note: In order to allow a break-in period for your vehicle, you may not be able to create a Vehicle Health Report until your vehicle odometer has reached 200 miles.
p55 v2
[added] Uploading photos for your home screen wallpaper
Your system allows you to upload and view up to 32 photos.
To access:
1. Press Menu > Display > Edit Wallpaper.
2. Follow the system prompts to upload your photographs.
Note: You can NOT load photos directly from your camera. You MUST access the photos from either your USB mass storage device or from an SD card.
Photo display limitations:
• Compatible file formats are as follows: .jpg, .gif, .png, .bmp
• Each file must be 1.5 MB or less.
• Recommended dimensions: 800 x 378
• Only the photograph(s) which meet these conditions will be displayed. Photographs with extremely large dimensions (i.e., 2048 x 1536) may not be compatible and will appear as a blank (black) image on the display.
p58 v2
[added] Active Park Assist (if equipped)
When activated, your system will display directions for you regarding the active park assist process. You can press 'Camera View' to also show the image from the rear camera on the touchscreen. For complete information on this system, please refer to Active Park
Assist in the Driving chapter of your Owner's Guide.
p58 v2
[added new destination choice] • Freeway Entrance/Exit
p66 v2
[added] Re-centering the map: Whenever you scroll the map away from your vehicle's current location, a centering icon will appear in the top left of the screen. Press this button to re-center the map back your vehicle's current location.
p68 v2
[added new text and picture] Map Scrolling: The map is touch sensitive, so you can use a swipe scrolling method (as you would on your portable music player) to scroll the map.
A scrolling circle appears in the center of the screen when in 3D map mode. Trace the circle with your finger to rotate the map.
Edited by revOevoM
p5 v1
p5 v2
p7 v2
p16 v2
p16 v1
p16 v2
p18 v1
p 18 v2
p19 v1
p19 v2
p22 v1
p22 v2
p24 v1
p24 v2
p29 v1
p31 v2
p30 v1
p31 v2
p32 v2
p40 v2
p43 v2
p47 v1
p48 v2
p55 v2
To access:
p58 v2
p58 v2
p66 v2
p68 v2
Thanks for all the work and research Moveover
  • 2 months later...
p5 v1
p5 v2
p7 v2
p16 v2
p16 v1
p16 v2
p18 v1
p 18 v2
p19 v1
p19 v2
p22 v1
p22 v2
p24 v1
p24 v2
p29 v1
p31 v2
p30 v1
p31 v2
p32 v2
p40 v2
p43 v2
p47 v1
p48 v2
p55 v2
To access:
p58 v2
p58 v2
p66 v2
p68 v2
Thanks
By the way has any body checked out Page 34 of the manual. The person who put this together must of had a sence of humor.
139.5 miles
28.5 MPG
300.5 Gal
58:44
Now I don't know about you but something looks wrong there. Either they had a fuel truck following it or a large fuel tank. Must of been a pretty straight road as well as you would have had to be going 140+ MPH
After four days I finally got everything set where I want it. Now just need to wait until spring to test it out.
