Sirius Module location in 07 Edge
Hi All,
Can I get some help on the location of the Sirius module in the 07 Edge. I purchased a used module from ebay and just need to know where it gets mounted and connected to the factory wiring. I am told the wiring is already in the vehicle from the factory and do not need any additional. Right or wrong please let me know. I have successfully changed the factory CD changer head unit to the Ford factory navigation head unit thanks to the wonderful people on this forum.
  On 10/2/2010 at 3:56 PM, grutledgem35 said:
Hi All,
When you say the Sirius module, I assume you mean the receiver. It is a black box. With the rear hatch open look down at the latch and then over to the left a little under the floor just aft of the spare tire. Mine says SAT on it followed by a series of numbers. It is attached to the car by a metal shield or bracket. There is a black wire that runs out of it along the left side of the car all the way up to the head unit.
Good luck with your install. I went with aftermarket equipment.
Thanks so much for your reply. I looked in the area you mentioned. removed the trim covering the latch. The cover over the spare tire and the storage bins on each side of the spare tire. The only wiring I see is the for wire bundles on each corner of the spare tire area which go under the vehicle. I also removed both side panels. The one on the right is where installed the factory amp and sub woofer. There were no spare plugs that I could see on the right. On the left hand side I found a black box about half way up to the window. I check the connector and it would not plug into the module that i purchased. I have attached a picture of the module that I purchase. the black box is about the size of 2 decks of cards. I am either missing some wiring or have the wrong module. I pulled the connector off of the small black box that i found. It looks like it is used for the electric seat release. Please let me know if i I am missing something. I checked all the way around the read latch, below it etc. You help is so appreciated.
Ford Satellite Radio Tuner PART#6L3T-18C963-AE.htmFetching info...
