Depiry Posted September 27, 2010 Report Share Posted September 27, 2010 1-Can the touch system be added to a 2010 Limited no-nav car? 2-are the dimensions the same? TIA,Marty Quote Link to comment Share on other sites More sharing options...
baum Posted September 27, 2010 Report Share Posted September 27, 2010 Short answer is NO the 11 are re-designed and will not work Quote Link to comment Share on other sites More sharing options...
rwbronco Posted September 29, 2010 Report Share Posted September 29, 2010 definitely not - the new AC/Radio controls below the nav are incorporated into it. It's also got a completely different steering wheel control and doesn't have the same buttons that the 2010 does Quote Link to comment Share on other sites More sharing options...
hndacr Posted November 29, 2010 Report Share Posted November 29, 2010 Seems they did not read your post. You absolutely can add factory nav to your 2010 edge. The system prior to MyFord Touch can be added. The system is actually better in most cases. It is plug and play electrically and mechanically with the addition of a couple simple components. Quote Link to comment Share on other sites More sharing options...
choff1138 Posted November 29, 2010 Report Share Posted November 29, 2010 (edited) Seems they did not read your post. You absolutely can add factory nav to your 2010 edge. The system prior to MyFord Touch can be added. The system is actually better in most cases. It is plug and play electrically and mechanically with the addition of a couple simple components. He wants to add the 2011 system to his 10 - it won't work according the other responses. At least that is how I took the question. Edited November 29, 2010 by choff1138 Quote Link to comment Share on other sites More sharing options...
