the_carguy22 Posted September 23, 2010 Report Share Posted September 23, 2010 I just purchased a Navigation Unit for my 2007 ford edge. it did not come with a Navigation system, but it does have the black antenna on the top of the car near the trunk. Is there any chance that this antenna is compatible with the Navigation Unit i purchased? it is from a mercury mountaineer, it is made by pioneer, the wires fit perfectly, and it fits my car and the radio works just fine (the only problem is the GPS wire). Please help!! If you need any just ask me! THANK YOU!!! Quote Link to comment Share on other sites More sharing options...
Neil Posted September 24, 2010 Report Share Posted September 24, 2010 I just purchased a Navigation Unit for my 2007 ford edge. it did not come with a Navigation system, but it does have the black antenna on the top of the car near the trunk. Is there any chance that this antenna is compatible with the Navigation Unit i purchased? it is from a mercury mountaineer, it is made by pioneer, the wires fit perfectly, and it fits my car and the radio works just fine (the only problem is the GPS wire). Please help!! If you need any just ask me! THANK YOU!!! No, the "puck" at the back would need to be replaced with a "puck" that would also have the GPS cable attached to it, which you would have to run through your headliner. A lot of work. You need to order the standard GPS antenna that goes under your dash or behind the Navigation unit. Quote Link to comment Share on other sites More sharing options...
the_carguy22 Posted September 24, 2010 Author Report Share Posted September 24, 2010 No, the "puck" at the back would need to be replaced with a "puck" that would also have the GPS cable attached to it, which you would have to run through your headliner. A lot of work. You need to order the standard GPS antenna that goes under your dash or behind the Navigation unit. Thanks for the information. Do you know the name of the antenna i need to order? Quote Link to comment Share on other sites More sharing options...
Neil Posted September 25, 2010 Report Share Posted September 25, 2010 Thanks for the information. Do you know the name of the antenna i need to order? Sure do... 7L3T-10E893-AA is the GPS antenna and cable for 2007 Ford Edge 8L3T-10E893-AA is the GPS antenna and cable for 2008 Ford Edge They are on ebay and amazon for $95 to $120 Good luck! Quote Link to comment Share on other sites More sharing options...
Bookworm Posted September 25, 2010 Report Share Posted September 25, 2010 Sure do... 7L3T-10E893-AA is the GPS antenna and cable for 2007 Ford Edge 8L3T-10E893-AA is the GPS antenna and cable for 2008 Ford Edge They are on ebay and amazon for $95 to $120 Good luck! Are you using some online source for these part numbers? If so I'd really love a link to it. I'm curious about part numbers for parts to upgrade my 2010 6 disc radio to a nav system. Quote Link to comment Share on other sites More sharing options...
Princessp64@gmail.com Posted August 5, 2013 Report Share Posted August 5, 2013 Hi! I have the ford edge 2007, not se etc. nothing special, lowest standard level and did not buy the navi system from factory, now I want to upgrade to the navigation system from ford. Can this be done at the dealer? And do u know the cost or part number? Thanks! Quote Link to comment Share on other sites More sharing options...
