pbdist Posted May 2, 2007 Report Share Posted May 2, 2007 Hello, Has anybody changed the radio system in the edge. I did not want to wait for the better radio and now I don't like the way the stock system sounds. I have the EdgeSEL Plus thanks, bryan Quote Link to comment Share on other sites More sharing options...
securinu Posted May 2, 2007 Report Share Posted May 2, 2007 pbdist said: Hello, Has anybody changed the radio system in the edge. I did not want to wait for the better radio and now I don't like the way the stock system sounds. I have the EdgeSEL Plus thanks, bryan Yeah we have done 4 or 5 for the dealers . My wife liked the car so much we went and ordered one. we put pioneer avic d3 in all but one for way less that the dealer wants for navi plus you can add everything to it for less than the dealer base navi unit. Quote Link to comment Share on other sites More sharing options...
Scott S Posted May 2, 2007 Report Share Posted May 2, 2007 securinu said: Yeah we have done 4 or 5 for the dealers . My wife liked the car so much we went and ordered one. we put pioneer avic d3 in all but one for way less that the dealer wants for navi plus you can add everything to it for less than the dealer base navi unit. That's a great idea! Any issues with the steering controls? Any other features that are not on the factory one? What "features" would you recommend adding? How about a kit for the edges with the components ready to plug in! How tough is the install? I also want to do the headrest DVD set up. Quote Link to comment Share on other sites More sharing options...
securinu Posted May 3, 2007 Report Share Posted May 3, 2007 Scott S said: That's a great idea! Any issues with the steering controls? Any other features that are not on the factory one? What "features" would you recommend adding? How about a kit for the edges with the components ready to plug in! How tough is the install? I also want to do the headrest DVD set up. No the steering wheel controls are simple and can be programmed for different features like mute or. Backup cam ipod on the screen plus charge xm w navtraffic to route around traffic sirius Bluetooth. The install is fairly simple if you get the plug in harness The only outside wires not at the radio are park brake and backup for a cam if you get that. As far as headrest we do Myron & Davis that match the leather or fabric and are flush inside the headrest. If your interested then you can call me at the shop ask for Joe just follow the link below. Quote Link to comment Share on other sites More sharing options...
alfarm2000 Posted May 8, 2007 Report Share Posted May 8, 2007 Securinu: What did you use to set up the steering whell controls? I tryied the pac-sw and for some reason is not letting me program it. thanks Quote Link to comment Share on other sites More sharing options...
securinu Posted May 9, 2007 Report Share Posted May 9, 2007 alfarm2000 said: Securinu: What did you use to set up the steering whell controls? I tryied the pac-sw and for some reason is not letting me program it. thanks We use the Peripheral Peswips you need to ground pin 19 of the main harness this is the feed from the radio to the steering wheel. then you also need a resistor on the purple wire on the control box Quote Link to comment Share on other sites More sharing options...
alfarm2000 Posted May 9, 2007 Report Share Posted May 9, 2007 securinu said: We use the Peripheral Peswipsyou need to ground pin 19 of the main harness this is the feed from the radio to the steering wheel. then you also need a resistor on the purple wire on the control box Thanks: The PAC-SW is the same thing but with a different name the instrucions are the same also, I guess I have done something wrong. I'll try it again this weekend. thanks Quote Link to comment Share on other sites More sharing options...
Scott S Posted May 9, 2007 Report Share Posted May 9, 2007 securinu said: No the steering wheel controls are simple and can be programmed for different features like mute or. Backup cam ipod on the screen plus charge xm w navtraffic to route around traffic sirius Bluetooth. The install is fairly simple if you get the plug in harness The only outside wires not at the radio are park brake and backup for a cam if you get that. As far as headrest we do Myron & Davis that match the leather or fabric and are flush inside the headrest. If your interested then you can call me at the shop ask for Joe just follow the link below. Thanks for the info! Quote Link to comment Share on other sites More sharing options...
pbdist Posted May 13, 2007 Author Report Share Posted May 13, 2007 Hello, Did you upgrade the speakers or keep the stock ones, If you keep the stock ones how did they sound? Also is there anything similar to the pioneer avic d3 that holds more then one disc at a time/ Thanks, Bryan securinu said: Yeah we have done 4 or 5 for the dealers . My wife liked the car so much we went and ordered one. we put pioneer avic d3 in all but one for way less that the dealer wants for navi plus you can add everything to it for less than the dealer base navi unit. Quote Link to comment Share on other sites More sharing options...
pbdist Posted June 2, 2007 Author Report Share Posted June 2, 2007 Hello, I just had this unit installed. I also had the steering control hooked up. When you say you can program it. do you program the controls from the unit? They hooked it up where the changing of the stations do not change from my preset channels. it changes the radio every .2 as if it was seeking. Can this be programmed to change from one preset station to the next? Thanks, Bryan No the steering wheel controls are simple and can be programmed for different features like mute or. Backup cam ipod on the screen plus charge xm w navtraffic to route around traffic sirius Bluetooth. The install is fairly simple if you get the plug in harness The only outside wires not at the radio are park brake and backup for a cam if you get that. As far as headrest we do Myron & Davis that match the leather or fabric and are flush inside the headrest. If your interested then you can call me at the shop ask for Joe just follow the link below. Quote Link to comment Share on other sites More sharing options...
wakblak Posted June 8, 2007 Report Share Posted June 8, 2007 pbdist said: Hello, I just had this unit installed. I also had the steering control hooked up. When you say you can program it. do you program the controls from the unit? They hooked it up where the changing of the stations do not change from my preset channels. it changes the radio every .2 as if it was seeking. Can this be programmed to change from one preset station to the next? Thanks, Bryan No the steering wheel controls are simple and can be programmed for different features like mute or. Backup cam ipod on the screen plus charge xm w navtraffic to route around traffic sirius Bluetooth. The install is fairly simple if you get the plug in harness The only outside wires not at the radio are park brake and backup for a cam if you get that. As far as headrest we do Myron & Davis that match the leather or fabric and are flush inside the headrest. If your interested then you can call me at the shop ask for Joe just follow the link below. Can the MKX stereo be changed out? I want to put my own navigation unit into it. Quote Link to comment Share on other sites More sharing options...
kali4nia58 Posted July 21, 2007 Report Share Posted July 21, 2007 securinu said: Yeah we have done 4 or 5 for the dealers . My wife liked the car so much we went and ordered one. we put pioneer avic d3 in all but one for way less that the dealer wants for navi plus you can add everything to it for less than the dealer base navi unit. do you have a picture of the unit installed in the edge? im curious to see if it looks natural. Thanks! Quote Link to comment Share on other sites More sharing options...
securinu Posted July 22, 2007 Report Share Posted July 22, 2007 (edited) Edited July 22, 2007 by securinu Quote Link to comment Share on other sites More sharing options...
securinu Posted July 22, 2007 Report Share Posted July 22, 2007 http://www.fordedgeforum.com/index.php?showtopic=571 Quote Link to comment Share on other sites More sharing options...
kali4nia58 Posted July 24, 2007 Report Share Posted July 24, 2007 securinu said: http://www.fordedgeforum.com/index.php?showtopic=571 Thank you! I went today and had that unit installed in my edge. I got the Sirius and ipod hooked up and ordered the bluetooth module. However, the steering wheel controls do not work. Should I have expected the controls to be set or can I go back and ask them to program the controls? Do I need to purchase something else for this? Thanks! I appreciate the advice! Quote Link to comment Share on other sites More sharing options...
securinu Posted July 24, 2007 Report Share Posted July 24, 2007 no it should have been working when you picked it up. Quote Link to comment Share on other sites More sharing options...
MHOsborn Posted July 24, 2007 Report Share Posted July 24, 2007 securinu said: no it should have been working when you picked it up. Speaking of radio changes, I got a quote yesterday from a local auto accessory shop that's done a lot of work for my Ford dealer. I was quoted an installed price of $1995 for a Pioneer AVIC D3, $250 for Sirius, and $75 for an iPod adapter. I wrote them back and questioned their pricing, as I've seen the Pioneer AVIC D3 at crutchfield.com for $899 (less at some other places). Either they're asking way too much for this change, or it takes at least 2 full days to install the unit. Quote Link to comment Share on other sites More sharing options...
securinu Posted July 24, 2007 Report Share Posted July 24, 2007 wow thats pricy are you sure it wasn a Z2 ??? we do the D3 Bluetooth steering wheel and either xm or sirius for $1500 installed at the local dealers. Quote Link to comment Share on other sites More sharing options...
MHOsborn Posted July 24, 2007 Report Share Posted July 24, 2007 securinu said: wow thats pricy are you sure it wasn a Z2 ??? we do the D3 Bluetooth steering wheel and either xm or sirius for $1500 installed at the local dealers. I thought it was way too pricey as well. I even questioned them about the Z2, as the price would be good for that unit. LOL...know of any installers in Tulsa I could use? Quote Link to comment Share on other sites More sharing options...
kali4nia58 Posted July 24, 2007 Report Share Posted July 24, 2007 MHOsborn said: Speaking of radio changes, I got a quote yesterday from a local auto accessory shop that's done a lot of work for my Ford dealer. I was quoted an installed price of $1995 for a Pioneer AVIC D3, $250 for Sirius, and $75 for an iPod adapter. I wrote them back and questioned their pricing, as I've seen the Pioneer AVIC D3 at crutchfield.com for $899 (less at some other places). Either they're asking way too much for this change, or it takes at least 2 full days to install the unit. I purchased my Pioneer AVIC D3 with Sirius and and iPod adpater and installation for about $1400 from Circuit City. I still need to purchase the Bluetooth adapter for about $180 from crutchfield and get it installed. Installation took a couple hours. Quote Link to comment Share on other sites More sharing options...
MHOsborn Posted July 24, 2007 Report Share Posted July 24, 2007 kali4nia58 said: I purchased my Pioneer AVIC D3 with Sirius and and iPod adpater and installation for about $1400 from Circuit City. I still need to purchase the Bluetooth adapter for about $180 from crutchfield and get it installed. Installation took a couple hours. I'm a little leery of Circuit City's installers here, as I've had two radios put in by their workers, and experienced problems with both installations. And...I wonder if they would have a clue regarding the steering wheel controls. Quote Link to comment Share on other sites More sharing options...
securinu Posted July 24, 2007 Report Share Posted July 24, 2007 If you want i can put it together here and ship it to you you would only need to get 2 wires and program the steering wheel control otherwise it would be plug & play. Quote Link to comment Share on other sites More sharing options...
MHOsborn Posted July 25, 2007 Report Share Posted July 25, 2007 securinu said: If you want i can put it together here and ship it to you you would only need to get 2 wires and program the steering wheel control otherwise it would be plug & play. I may take you up on that....I won't know for sure until I buy our new car, though. Thanks! Quote Link to comment Share on other sites More sharing options...
MHOsborn Posted July 26, 2007 Report Share Posted July 26, 2007 MHOsborn said: I may take you up on that....I won't know for sure until I buy our new car, though. Thanks! Just received an email from that company yesterday. Now they're saying they'll give me their "dealer price" of $1500. I'll find out if this price includes Sirius, Bluetooth, and steering wheel controls (but I doubt it). They're saying the Sirius adapter for the Pioneer AVIC D3 is on national back order. It's listed as out of stock at crutchfield. You seeing the same thing? Quote Link to comment Share on other sites More sharing options...
securinu Posted July 26, 2007 Report Share Posted July 26, 2007 no we have them in stock(sirius) and the avic d3 sells for $999MAP and $1099msrp Quote Link to comment Share on other sites More sharing options...
