thekingrobert Posted September 15, 2010 Report Share Posted September 15, 2010 I have a 2007 SEL Edge purchased pre-owned about two weeks ago. It had the Sirius sticker on the window so I purchased it thinking it would be easy to program. But when I try to activate from online while the car's radio is set on 184 nothing happens. This is the factory 6 disc radio any help would be appreciated thanks. Quote Link to comment Share on other sites More sharing options...
grutledgem35 Posted September 21, 2010 Report Share Posted September 21, 2010 I have a 2007 SEL Edge purchased pre-owned about two weeks ago. It had the Sirius sticker on the window so I purchased it thinking it would be easy to program. But when I try to activate from online while the car's radio is set on 184 nothing happens. This is the factory 6 disc radio any help would be appreciated thanks. Do you have the SR option to select on you system? If not it will require a dealer reprogram to re-enable the satellite option. There should be AM, FM1,FM2, SR, Line. I know this as I just took mine to the dealer to have it programmed. I replaced the standard 6 disc changer with a navigation unit. All I needed was a VIN # that had the Satellite option. Quote Link to comment Share on other sites More sharing options...
