Updating Sync / MyFord Touch
lakleeman
I'll ask this here because the "Sync Forum" only seems to contain folks with pre-2011 Syncs (missing the MyFord Touch feature)....
Has anyone gone to the syncmyride.com website and downloaded the update. I did, and it said there was an update. I downloaded it and successfully installed it on my 2011 Ford Edge. Then, I brought the USB stick back to my desktop to "report successful install" but I got an error uploading the report.
Ford Chat help did NOT help. They said I didn't need an update - I get the impression the chat folks are not as knowledgable on MyFord Touch.
I also emailed Sync - which is what it says to do if there's an error when reporting successful installs -- and I'm waiting to hear back.
Anyway, I'm curious ... has anyone else successfully done an update? and successfully reported it back to their sync web account?
  On 9/13/2010 at 10:52 PM, rwbronco said:
are you sure that you need an update? It wouldn't appear that you'd need to update a 2011 Edge with the myFordTouch yet. I know they're installing it wirelessly now as it rolls down the assembly line and they're likely using the newest updated version.
I normally wouldn't think I'd need an update either, but the sync website showed what I have installed as of August 10 (presumably at the factory), then showed that an update is available too -- with a newer version number.
I did hear back from Ford via email saying I don't need an update. (The Sync website still says otherwise.)
Edited by lakleeman
I agree with those guys. I actually had a 2010 Edge and successfully completed the update from syncmyride.com and received the "successful upload report." I did not think to upload the software to the MyFord Touch because I believe it is a different system. I wonder if they will start a new website for those with MyFord Touch.
