Strange Mirror Movement
Hello, i drive a 2008 Lincoln MKX. Since a few month the right (passenger) side mirror is move every time i push the open door button. I can program the memory operation, but even with new programming the next time the mirror will move somewhere. Sometimes to the end of way till it knock! I tried the second key (with my girlfriends settings) and used mine after that. The Seat and driver side mirror is fine, only the passenger side has his own life!
Some ideas? It´s really annoying to adjust the mirror after open the door - nearly every time.
Ralf
Ralf
I had my MKX at the dealer because the mirrors would move a little and stop. After replacing some modules and switches they finally replaced both motors and that took care of it. FWIW, they had the car for 2 weeks trying to figure it out.
Ralf
had the same problem 2 times on my 2007 edge. they fixed it by replacing some sort of module in the driver seat. was told that is were the mirrors are controlled from. both times it was covered under warranty.
m
