dipper44 Posted May 1, 2007 Report Share Posted May 1, 2007 I got my Edge in March and although the gas mpg is baddddddddd two new problems have surfaced. There is a rattle coming from back seat area that the dealer can't find. Also on AM radio station there is a lot of static that increases when the fan is turned up. The dealer checked connections etc but can not fix it. They tried the radio on another Edge and it did the same thing. Other cars do not have the same problem. Can someone offer any suggestions???????? Quote Link to comment Share on other sites More sharing options...
sntmods Posted May 1, 2007 Report Share Posted May 1, 2007 I got my Edge in March and although the gas mpg is baddddddddd two new problems have surfaced.There is a rattle coming from back seat area that the dealer can't find. Also on AM radio station there is a lot of static that increases when the fan is turned up. The dealer checked connections etc but can not fix it. They tried the radio on another Edge and it did the same thing. Other cars do not have the same problem. Can someone offer any suggestions???????? the gas mileage thing is your fault, take it easy on the pedal and change your style of driving. The advertised numbers are very obtainable. I can get 17/24 when I watch my driving. I cant help you with the static but the rattle may be coming from the spare tire hold down. -Dan Quote Link to comment Share on other sites More sharing options...
hotnuts Posted May 1, 2007 Report Share Posted May 1, 2007 the gas mileage thing is your fault, take it easy on the pedal and change your style of driving. The advertised numbers are very obtainable. I can get 17/24 when I watch my driving. I cant help you with the static but the rattle may be coming from the spare tire hold down. -Dan i can help with static change to fm . thats my the made fm. Quote Link to comment Share on other sites More sharing options...
nlr Posted May 1, 2007 Report Share Posted May 1, 2007 I had a rattle towards the back and it was the license plate holder on the back end. Padded it, and no more rattle. I am not having any problem with static on the radio so can't help you with that one. My MPG is getting very close to what was advertised and I only have about 500 miles on my Edge. I got my Edge in March and although the gas mpg is baddddddddd two new problems have surfaced.There is a rattle coming from back seat area that the dealer can't find. Also on AM radio station there is a lot of static that increases when the fan is turned up. The dealer checked connections etc but can not fix it. They tried the radio on another Edge and it did the same thing. Other cars do not have the same problem. Can someone offer any suggestions???????? Quote Link to comment Share on other sites More sharing options...
glenn1104 Posted May 2, 2007 Report Share Posted May 2, 2007 I got my Edge in March and although the gas mpg is baddddddddd two new problems have surfaced.There is a rattle coming from back seat area that the dealer can't find. Also on AM radio station there is a lot of static that increases when the fan is turned up. The dealer checked connections etc but can not fix it. They tried the radio on another Edge and it did the same thing. Other cars do not have the same problem. Can someone offer any suggestions???????? If you have the Vista Roof, I noticed a rattle coming from the rear sun roof. The plastic trim inside the car around the rear sun roof comes loose and rattles. You can stick it back in place but it will just come loose again, take it to the dealer to get fixed Quote Link to comment Share on other sites More sharing options...
brucesmays Posted July 22, 2007 Report Share Posted July 22, 2007 I had a rattle in the rear area, the spare tire hold down was loose. Quote Link to comment Share on other sites More sharing options...
