ark Posted September 1, 2010 Report Share Posted September 1, 2010 ok so the problem is that when i connect my "old" ipod nano to my 2010 edge it charges but doesn't play, and when i use that voice commander and say "USB" the voice commander or whatever it's called it says that there's no usb device connected. so any help? Quote Link to comment Share on other sites More sharing options...
igcitng Posted September 1, 2010 Report Share Posted September 1, 2010 This just happened to me. Pull fuse # 3, check it and if it is fine put it back and then try it. Quote Link to comment Share on other sites More sharing options...
ark Posted September 1, 2010 Author Report Share Posted September 1, 2010 ok this is embarrassing but what is fuse #3? i mean where is it? Quote Link to comment Share on other sites More sharing options...
jeff_h Posted September 1, 2010 Report Share Posted September 1, 2010 ok so the problem is that when i connect my "old" ipod nano to my 2010 edge it charges but doesn't play, and when i use that voice commander and say "USB" the voice commander or whatever it's called it says that there's no usb device connected.so any help? You may also want to reboot your iPod and then try again, I've found the Nanos to be more finicky than the old clunky but trusty iPod Mini that I used to have. Hold center button and "menu" at the same time for about 3-5 seconds, screen will go blank and then the apple icon will show, let go of buttons and it will take about 5-10 seconds or so to come back to main screen -- then try to connect to USB and Sync and see how it goes. Quote Link to comment Share on other sites More sharing options...
rwbronco Posted September 2, 2010 Report Share Posted September 2, 2010 I've got an iPhone and stream mine via bluetooth so I can't say first hand what to do with your nano but rebooting it while it's plugged in should be the first thing you do - report back with whether or not it worked Quote Link to comment Share on other sites More sharing options...
igcitng Posted September 2, 2010 Report Share Posted September 2, 2010 If the reboot does not work, the fuse box is on the drivers side on the outer wall by the door hinges. Hopefully the fuse puller is there, mine was gone so I had to go get one because #3 is hard to get to and a pliers couldn't get to it. When mine said no usb I rebooted the ipod, plugged/unplugged, and even did a master reset on the Sync. Only thing that worked was pulling the fuse. Quote Link to comment Share on other sites More sharing options...
ark Posted September 2, 2010 Author Report Share Posted September 2, 2010 ok when i get to my car i'll try the rebooting thing 1st. but i still don't know where's the fuse, is it near the steering wheel or the lights switch? Quote Link to comment Share on other sites More sharing options...
1duFos Posted September 3, 2010 Report Share Posted September 3, 2010 ok when i get to my car i'll try the rebooting thing 1st. but i still don't know where's the fuse, is it near the steering wheel or the lights switch? Would the manual show where the fuse box is? Quote Link to comment Share on other sites More sharing options...
igcitng Posted September 3, 2010 Report Share Posted September 3, 2010 Would the manual show where the fuse box is? Yes but it is very easy to find. It is on the drivers side down toward the floor where the door and front fender meet, by the hinges you could say. There is a little door on it. Near the parking brake. Quote Link to comment Share on other sites More sharing options...
rwbronco Posted September 6, 2010 Report Share Posted September 6, 2010 So I have an iPad and an iPhone and the other day the bluetooth music quit working on both of them. The phone would still make calls using Sync/bluetooth but the music would not work in the "media" menu on the screen (I have nav). I would select iPad or iPhone and hit connect and it would never show the green and blue arrows letting me know it was indeed connected. I pulled Fuse #3 and waited 30 seconds or so and popped it back in. Connected right up and started playing music. I hope I don't have to do this often! Fuse box on the inside is easy to reach. It's got a hinge on the side facing you so once you get the tabs loose on the bottom just swing it towards you (might have to depress teh parking brake to let it clear). It looks a little different than the image on the fuse panel cover but they're in the same order. It comes out easy and doesn't matter if you flip it around on accident when putting it back in since a fuse works both ways. Quote Link to comment Share on other sites More sharing options...
manat Posted January 24, 2011 Report Share Posted January 24, 2011 I am thinking of buying a new ipod nano having elegant skin soon, So could anyone here please suggest me some websites providing ipod nano 5th gen with nice skins? nano 5th gen skin cover Quote Link to comment Share on other sites More sharing options...
