07_edge_sel Posted August 23, 2010 Report Share Posted August 23, 2010 I've been reading the forums about the wheel bearing roar. I was looking to replace my tires, but after doing some research, found that the wheel bearing/hub failures where an issue. I have 57,000 miles on the Edge, and was told by the dealer that the powertrain warranty does not cover the wheel bearings/hub assy's. Does anyone have the part number for the rear and front hub assy's? Is this a dealer only part? Thanks. Quote Link to comment Share on other sites More sharing options...
gcorson Posted September 10, 2010 Report Share Posted September 10, 2010 (edited) I have now replaced the rear wheel bearings twice on my 07 edge. The second set was just replaced at 82,000 miles. The first set at about 50,000, but the first set was covered by warranty. They told me that this replacement was an updated knuckle and bearing. This is obviously an under design issue, but all my efforts to discuss it with Ford Customer Service have fallen on deaf ears so I am stuck with the bill. I have worked in the bearing industry for 30 years and I can tell you that wheel bearings should not fail even once in 100,000 miles. Yes, there is the odd case of a bad bearing or other defect related to the installation, but if the bearing had been designed properly, I would have had more chance of winning the lottery, than failing 2 bearings in 50,000 miles and the failing 2 more in only another 30,000. Edited September 10, 2010 by gcorson Quote Link to comment Share on other sites More sharing options...
Paul79UF Posted October 16, 2010 Report Share Posted October 16, 2010 On 9/10/2010 at 10:16 PM, gcorson said: I have now replaced the rear wheel bearings twice on my 07 edge. The second set was just replaced at 82,000 miles. The first set at about 50,000, but the first set was covered by warranty. They told me that this replacement was an updated knuckle and bearing. This is obviously an under design issue, but all my efforts to discuss it with Ford Customer Service have fallen on deaf ears so I am stuck with the bill. I have worked in the bearing industry for 30 years and I can tell you that wheel bearings should not fail even once in 100,000 miles. Yes, there is the odd case of a bad bearing or other defect related to the installation, but if the bearing had been designed properly, I would have had more chance of winning the lottery, than failing 2 bearings in 50,000 miles and the failing 2 more in only another 30,000. Reminds me of my '01 Grand Prix. The two front bearings were so loud at 75k miles. The rear ones are just now starting to get louder at 100k. So should the 2010 have the updated part? Quote Link to comment Share on other sites More sharing options...
revo1059 Posted October 19, 2010 Report Share Posted October 19, 2010 On 10/16/2010 at 6:05 PM, Paul79UF said: Reminds me of my '01 Grand Prix. The two front bearings were so loud at 75k miles. The rear ones are just now starting to get louder at 100k. So should the 2010 have the updated part? I just had both replaced on my 2008 for the 2nd time (with only 32k miles) and this time I was told there was a new bracket that they installed on both sides that should keep it from happening again. Quote Link to comment Share on other sites More sharing options...
Ghastly Posted February 3, 2011 Report Share Posted February 3, 2011 Can anyone verify whether or not this is covered under the 5 / 60,000 warranty? I began hearing the "humming" about a week ago. Gets "higher" as I go faster, so I know it's not the exhaust. From the descriptions above, I think I have the wheel bearing issue as well. I have an 08 and am just above 56k miles and would rather not have to pay for this if it's becomming a common issue. Thanks in advance! On 10/19/2010 at 2:59 PM, revo1059 said: I just had both replaced on my 2008 for the 2nd time (with only 32k miles) and this time I was told there was a new bracket that they installed on both sides that should keep it from happening again. Quote Link to comment Share on other sites More sharing options...
ThinLine Posted February 3, 2011 Report Share Posted February 3, 2011 It specifically states in the glove box warranty manual that front and rear bearings are covered under the 5 year 60,000 warranty. I don't know the page number as the car is actually at ford as I type this. Quote Link to comment Share on other sites More sharing options...
val Posted June 20, 2011 Report Share Posted June 20, 2011 (edited) On 2/3/2011 at 3:53 PM, ThinLine said: It specifically states in the glove box warranty manual that front and rear bearings are covered under the 5 year 60,000 warranty. I don't know the page number as the car is actually at ford as I type this. GOSH! Thank you so much! Taking my 2009 Edge in tomorrow and they are saying the rear bearings are NOT covered. I will look for this tonight. Thanks again for your post! Edited June 20, 2011 by val Quote Link to comment Share on other sites More sharing options...
vleutschaft Posted August 15, 2013 Report Share Posted August 15, 2013 Does anyone know if the 2010 Edge is covered by the TSB # 10-2-9? Thanks. Quote Link to comment Share on other sites More sharing options...
Cindy Posted August 21, 2013 Report Share Posted August 21, 2013 I am having the roaring that everyone is talking about with the wheel bearings in the rear. I have a 2008 Edge with only 28,000 miles on it, very low. My 5 year warranty was up last December. I have the TSB printed regarding this and will be taking it with me to the Ford Dealership on Friday to have them listen to it. Is there anyway possible with low miles and it just expiring last December that I can get them to pay for this repair. Any idea how spendy it could get. I looked on Complaints filed with Ford and there are several regarding this issue. Thanks for any helpful answers. Quote Link to comment Share on other sites More sharing options...
sylvainm Posted September 19, 2014 Report Share Posted September 19, 2014 I also had that roaring noise coming from the back of my 2012 Edge for a few weeks now, with only 63,000 km on the meter. I went to my Ford dealer this week and they replaced a rear wheel bearing-hub assembly. It was passed on the powertrain warranty; so it was at no charge to me. Quote Link to comment Share on other sites More sharing options...
akirby Posted September 19, 2014 Report Share Posted September 19, 2014 Strange that it's part of the PT warranty. Good, but strange. I guess in some cases they're connected to the engine, but still.... Quote Link to comment Share on other sites More sharing options...
sylvainm Posted September 19, 2014 Report Share Posted September 19, 2014 Here's a link to the PT Warranty (US version). Check on page 11. Front and Rear Wheel Drives are part of the Powertrain. http://www.fordservicecontent.com/Ford_Content/catalog/owner_guides/12frdwa5e.pdf Quote Link to comment Share on other sites More sharing options...
ponder3 Posted October 13, 2014 Report Share Posted October 13, 2014 I have a 2012 Ford Edge rear wheels roaring they said it was covered, getting them replaced tomorrow with 58500 miles on it. Quote Link to comment Share on other sites More sharing options...
akirby Posted October 13, 2014 Report Share Posted October 13, 2014 They're covered under the powertrain warranty (believe it or not). Quote Link to comment Share on other sites More sharing options...
