Sync usb not working
Yesterday morning my Sync usb that I have my iPod on worked fine. In the afternoon it did not and will not. The iPod always stayed connected and is only removed to update it once in awhile. I have done everything I can think of to remedy the situation:
unplugged/plugged in usb
unplugged/plugged in iPod
Tried a different usb cord
Turned on and off the iPod
Did a master reset
The usb will not charge the iPod either, seems to be no power to it. My iPhone streams to Sync just fine.
Anything else I can do or is it just fried? Thanks.
Did a master reset
Sounds like the fuse is gone, check the fuse. :yup:
This was an adventure. Sparky said to check the fuse, so I set out to do that. Got out the manual, found the fuse box. Apparently someone had already been in there. The cover was on crooked and there were greasy handprints all over. The fuse removal tool was missing, all that was there was the piece of tape that probobly originally held it to the back of the cover. Could not get to it with a pliers, it is the third fuse on the top left. So off to the automotive store to get a tool and fuse kit. Crawl back in there, get the fuse and it is fine. I put it back so that everything is the way it was to go to the dealer to get fixed. Well, I could not have been happier when for yucks and grins I double checked to see if my iPod would work and it did. Works just fine now. Weird. And honestly, I don't know mechanics work on this stuff, I could barely get in there to it let alone a large man with larger hands. Wow.
Thanks Sparky. :)
Thanks Sparky. :)
No problem, glad your Ipod is working fine. :yup:
