jpeckinp Posted August 5, 2010 Report Share Posted August 5, 2010 Well I replaced the cabin filter on my '10 Edge Limited and I must say it was easier on my '08. I ordered the Fram filter with Arm & Hammer part # CF10547 The filter isn't an exact replacement like I thought. You have to remove the filter from the plastic frame that it is enclosed in, then you have to push the filter in the slot paying close attention to a small plastic tab that sticks down. You have to lightly push past the tab and then the filter will go in the spot perfectly. This is the cheapest I could find it. Amazon Quote Link to comment Share on other sites More sharing options...
Depiry Posted September 1, 2010 Report Share Posted September 1, 2010 Do the cabin air filters have activated charcoal? thanks Marty Quote Link to comment Share on other sites More sharing options...
jeff_h Posted September 1, 2010 Report Share Posted September 1, 2010 Do the cabin air filters have activated charcoal? thanks Marty No, they are just white plastic frame with white paper-type filter element. Appears to cost about $1 to make but sells for about $10-20 or whatever the OP's Amazon link shows, not much to the filters actually. Quote Link to comment Share on other sites More sharing options...
Depiry Posted September 2, 2010 Report Share Posted September 2, 2010 (edited) I bought Hastings filter ,it's just molded filter material no separate frame for $10.,pretty cheesy,Marty Just like one ply. Edited September 2, 2010 by Depiry Quote Link to comment Share on other sites More sharing options...
bigalx58 Posted October 25, 2010 Report Share Posted October 25, 2010 From what I have seen of the cabin filter, it looks very similar to some cheaper house furnace filters...the ones that have only a thin piece of hard paper as a filter. You could probably cut the furnace filter to fit into the cabin filter slot. Anyone tried this? Quote Link to comment Share on other sites More sharing options...
Depiry Posted November 15, 2010 Report Share Posted November 15, 2010 (edited) I replaced the cabin filter yesterday,17500 miles ,about 14 months,3 ribs filled about 1/4 of the way up with debris,rest of filter black,needs replacement sooner,Marty Edited December 10, 2010 by Depiry Quote Link to comment Share on other sites More sharing options...
bookemdano Posted December 10, 2010 Report Share Posted December 10, 2010 (edited) Can someone tell me where to find this filter at on the 2010 Edge? Appreciate it, Dano Edited December 10, 2010 by bookemdano Quote Link to comment Share on other sites More sharing options...
Depiry Posted December 10, 2010 Report Share Posted December 10, 2010 (edited) Behind the glove box,Marty Edited December 10, 2010 by Depiry Quote Link to comment Share on other sites More sharing options...
bookemdano Posted December 22, 2010 Report Share Posted December 22, 2010 Behind the glove box,Marty Thanks Marty. When it warms up a bit, I'll check it out. Dano Quote Link to comment Share on other sites More sharing options...
foxracermenace Posted December 27, 2010 Report Share Posted December 27, 2010 Remove your glovebox for easier access. Quote Link to comment Share on other sites More sharing options...
bookemdano Posted December 28, 2010 Report Share Posted December 28, 2010 Remove your glovebox for easier access. My 2010 has a screen type filter. Took it out and vacuumed it and it cleaned up real well. Probably have to replace it after a couple cleanings because it didn't strike me as real strong. Anyway it should be good for a year or at least a couple oil changes before it needs cleaned again. Thanks, Dano Quote Link to comment Share on other sites More sharing options...
