Tdoggz28 Posted July 11, 2010 Report Share Posted July 11, 2010 I tried to reactivate the sirius in my 08 Edge but when I hit the Aux button i get a SAT FAULT message on the display. Was able to get the code B1342 SAT to come up but not sure were to go from there. Any one know if there is a "master reset" fot this unit. It is not a touch screen unit just regular. I can replace the sirus module if neccessary but wanted to make sure it was the problem. Any help is greatly appriecated. Quote Link to comment Share on other sites More sharing options...
roady123 Posted August 31, 2010 Report Share Posted August 31, 2010 I tried to reactivate the sirius in my 08 Edge but when I hit the Aux button i get a SAT FAULT message on the display. Was able to get the code B1342 SAT to come up but not sure were to go from there. Any one know if there is a "master reset" fot this unit. It is not a touch screen unit just regular. I can replace the sirus module if neccessary but wanted to make sure it was the problem. Any help is greatly appriecated. Hey did you solve it? I have tried I few things - no luck so far. Unplugging the power unit did nothing, calling sirisu did nothing, and pulling a few related fuses did not work either. Please let me know what (if anything) solved it for you. Quote Link to comment Share on other sites More sharing options...
Platinum White Posted September 2, 2010 Report Share Posted September 2, 2010 I had "Sat Fault" show up a while back, went to dealer and they replaced the Sirius receiver under warranty. Everything works fine now. Quote Link to comment Share on other sites More sharing options...
er65nsunny Posted September 2, 2010 Report Share Posted September 2, 2010 According to the workshop manual B1342 relating to sirius is the module. The dealer will clear the DTC's and if the code shows up again the module will have to be replaced. Quote Link to comment Share on other sites More sharing options...
roady123 Posted September 20, 2010 Report Share Posted September 20, 2010 Is there a deductible for the warranty? Quote Link to comment Share on other sites More sharing options...
akirby Posted September 20, 2010 Report Share Posted September 20, 2010 Is there a deductible for the warranty? Not for the factory warranty. If you bought an extended warranty then it depends on which option you purchased - could be $0 - $500 or more depending on the warranty. Should be in your extended warranty paperwork. Quote Link to comment Share on other sites More sharing options...
roady123 Posted September 22, 2010 Report Share Posted September 22, 2010 Thanks - I'm at 24,000 so I'm still under the factory. I did buy the extended though -$100 deduct. Still bugs me as to why the "sat fault" came up. Any thoughts? Quote Link to comment Share on other sites More sharing options...
