JustLiam Posted July 3, 2010 Report Share Posted July 3, 2010 I know it sounds ridiculous but Ive replaced numerous batteries in my cars before. I cannot figure out for the life of me how to remove the battery from my 2007 Ford Edge. Does anyone know or has anyone replaced one from an edge before? Thank you Quote Link to comment Share on other sites More sharing options...
ablb Posted July 3, 2010 Report Share Posted July 3, 2010 (edited) I know it sounds ridiculous but Ive replaced numerous batteries in my cars before. I cannot figure out for the life of me how to remove the battery from my 2007 Ford Edge. Does anyone know or has anyone replaced one from an edge before? Thank you Greetings and welcome We havent changed our 08 yet but it looks pretty easy??? 10mm wrench takes the cables off and an 8mm for the LONG bolt that holds it in. Are you having trouble getting it past the air filter? You might need to take the top off the air filter??? ab Edited July 3, 2010 by ablb Quote Link to comment Share on other sites More sharing options...
JustLiam Posted July 3, 2010 Author Report Share Posted July 3, 2010 Greetings and welcome We haven’t changed our 08 yet but it looks pretty easy??? 10mm wrench takes the cables off and an 8mm for the LONG bolt that holds it in. Are you having trouble getting it past the air filter? You might need to take the top off the air filter??? ab Let me first say thank you for your reply. I figured out what the issue was. My problem was after I loosened the nuts. Nothing was coming apart. The cables were still connected even when I unscrewed everything. Turns out you just need to go into it with the attitude of "no matter how hard I pull on medal pieces, it wont break". Lol, seriously though, it just took some heavy force and alot of wiggling. Came right off. Thanks for replying though, Quote Link to comment Share on other sites More sharing options...
wkevingossett Posted July 4, 2010 Report Share Posted July 4, 2010 I ruined a good battery by trying to remove the positive cable... It absolutely wouldn't budge! The post actually separated from the battery Quote Link to comment Share on other sites More sharing options...
