mike6ds Posted June 29, 2010 Report Share Posted June 29, 2010 I took my 2007 Edge to the dealer this week and let them do the TSB on the rear moonroof. Sadly, they actually made the squeak worse. After having my wife drive me around while i was in the back I found the source of the squeak. The squeak is coming from a styrofoam support piece under the corner of the headliner. Has anyone else had this issue? I'm able to put my hand against the styrofoam to get the squeak to stop. Does anyone have any ideas on how i can fix this issue? I'm thinking i can get something to wedge against it it'll fix it, but i'd like to hear other ideas first. styrofoam piece is under the circled area. Rear moonroof, passenger side, front corner Quote Link to comment Share on other sites More sharing options...
alfaromeo Posted July 1, 2010 Report Share Posted July 1, 2010 I have no idea. My vehicle is still on the way to me. At least, we can talk with dealer technicians. Quote Link to comment Share on other sites More sharing options...
mccolganr Posted July 13, 2010 Report Share Posted July 13, 2010 I took my 2007 Edge to the dealer this week and let them do the TSB on the rear moonroof. Sadly, they actually made the squeak worse. After having my wife drive me around while i was in the back I found the source of the squeak. The squeak is coming from a styrofoam support piece under the corner of the headliner. Has anyone else had this issue? I'm able to put my hand against the styrofoam to get the squeak to stop. Does anyone have any ideas on how i can fix this issue? I'm thinking i can get something to wedge against it it'll fix it, but i'd like to hear other ideas first. styrofoam piece is under the circled area. Rear moonroof, passenger side, front corner Any resolution to this? I have a 2010 and almost the same issue, mine seems to come from the FRONT moonroof, passenger side, REAR corner Quote Link to comment Share on other sites More sharing options...
livinonthedge Posted July 13, 2010 Report Share Posted July 13, 2010 Can it be glued down with a automotive adhesive? Quote Link to comment Share on other sites More sharing options...
mike6ds Posted July 16, 2010 Author Report Share Posted July 16, 2010 Any resolution to this? I have a 2010 and almost the same issue, mine seems to come from the FRONT moonroof, passenger side, REAR corner I've wedged a piece of cardboard between the styrofoam piece and the roof where I thought was the rattle and it's held for a past two weeks! Quote Link to comment Share on other sites More sharing options...
mike6ds Posted July 16, 2010 Author Report Share Posted July 16, 2010 Can it be glued down with a automotive adhesive? I would be a little scared to do so since I can't really see but only feel where the issue is. Quote Link to comment Share on other sites More sharing options...
DJ Nap Posted July 18, 2010 Report Share Posted July 18, 2010 My '07 has recently started to squeak bad, I assumed it was the glass against rubber noise, but this makes more sense. I'll take a peek tomorrow. Thanks! Quote Link to comment Share on other sites More sharing options...
CDS Posted September 12, 2010 Report Share Posted September 12, 2010 My '07 has recently started to squeak bad, I assumed it was the glass against rubber noise, but this makes more sense. I'll take a peek tomorrow. Thanks! My 2010 is squeaking as well.. It seems that when I open the sunroof it stops though. So I am wondering if it is in fact the rear sunroof as you guys have stated? Seems that it should be related to the front sunroof? Anyone else have the same issue? I will have a look at the Styrofoam that you mentioned as well. thanks... Quote Link to comment Share on other sites More sharing options...
Rasurec Posted May 29, 2011 Report Share Posted May 29, 2011 I see this post is pretty old, but I have the exact same squeaking issue (also related to the Styrofoam block found at the front passenger side of the rear moon-roof). It seems to get worse as the Texas days heat up- an annoying squeak, squeak, squeak unless you're on the absolute smoothest of roads. Pushing up on the headliner near the corner of the moon-roof halts the squeak. Before I MacGyver a repair, did anyone else find an acceptable solution? And is this directly related to the much-mentioned BAMR trim ring rattle? I don't notice a rattle, just the squeaky Styrofoam. 2008 Edge Limited Quote Link to comment Share on other sites More sharing options...
