Grupet Posted June 22, 2010 Report Share Posted June 22, 2010 Anybody having problem with sync after updating there iPhone to iOS4? Mine wont import my Phones contacts anymore and it keeps calling itself... Others with same or other problems? Quote Link to comment Share on other sites More sharing options...
mike6ds Posted June 23, 2010 Report Share Posted June 23, 2010 I'm about to update my 3g. I'll let you know how it goes. Anybody having problem with sync after updating there iPhone to iOS4? Mine wont import my Phones contacts anymore and it keeps calling itself... Others with same or other problems? Quote Link to comment Share on other sites More sharing options...
Grupet Posted June 23, 2010 Author Report Share Posted June 23, 2010 I'm about to update my 3g. I'll let you know how it goes. Thanks... But now i have a new problem... I deleted the iPhone from SYNC, because i wanted to re-pair it, but now sync can't find the iPhone, so now nothing is working :-( None of my devices (Garmin navigation, MacBook Pro, iPad) can find the iPhone after updating to iOS4 Quote Link to comment Share on other sites More sharing options...
akirby Posted June 23, 2010 Report Share Posted June 23, 2010 Thanks... But now i have a new problem... I deleted the iPhone from SYNC, because i wanted to re-pair it, but now sync can't find the iPhone, so now nothing is working :-( None of my devices (Garmin navigation, MacBook Pro, iPad) can find the iPhone after updating to iOS4 Did you turn bluetooth on? It was probably reset to off with the upgrade. Quote Link to comment Share on other sites More sharing options...
Grupet Posted June 23, 2010 Author Report Share Posted June 23, 2010 Did you turn bluetooth on? It was probably reset to off with the upgrade. Yes, my Bluetooth is turn on ;-) Quote Link to comment Share on other sites More sharing options...
igcitng Posted June 23, 2010 Report Share Posted June 23, 2010 Resync the iPhone and reboot it and try again. Mine is fine. And be sure that you actually deleted it from Ford Sync, if it is still there it won't let you add another. Quote Link to comment Share on other sites More sharing options...
Grupet Posted June 23, 2010 Author Report Share Posted June 23, 2010 Resync the iPhone and reboot it and try again. Mine is fine. And be sure that you actually deleted it from Ford Sync, if it is still there it won't let you add another. The problem is my Bluetooth is not working after udating to iOS4. I can't pair it to any of my devices like SYNC, Macbook and iPad... :-( Quote Link to comment Share on other sites More sharing options...
igcitng Posted June 23, 2010 Report Share Posted June 23, 2010 The problem is my Bluetooth is not working after udating to iOS4. I can't pair it to any of my devices like SYNC, Macbook and iPad... :-( Why I am suggesting re-syncing the iPhone with iTunes and rebooting it. If it did not completely load it won't work correctly. That update was long and there was a second update that needed to be downloaded after the initial one. If it is not syncing with all of those devices it sounds like the phone is the common denominator. Hopefully it works for you soon. Quote Link to comment Share on other sites More sharing options...
kosh Posted June 23, 2010 Report Share Posted June 23, 2010 Mine is working fine after iOS4! Quote Link to comment Share on other sites More sharing options...
Grupet Posted June 25, 2010 Author Report Share Posted June 25, 2010 I bought the new iPhone 4 yesterday and it finds SYNC and it works with SYNC, but it still wont download my phonebook... very strange?? Quote Link to comment Share on other sites More sharing options...
barbieann Posted July 13, 2010 Report Share Posted July 13, 2010 Thanks... But now i have a new problem... I deleted the iPhone from SYNC, because i wanted to re-pair it, but now sync can't find the iPhone, so now nothing is working :-( None of my devices (Garmin navigation, MacBook Pro, iPad) can find the iPhone after updating to iOS4 i am having the same problem. cannot get it to re- pair blue tooth does not seem to work. tried re installing update no help. any other suggestions? Quote Link to comment Share on other sites More sharing options...
Sparky Posted July 13, 2010 Report Share Posted July 13, 2010 i am having the same problem. cannot get it to re- pair blue tooth does not seem to work. tried re installing update no help. any other suggestions? I would go back to OS3. it's easy process just google it and you should have no problem. I did the update to OS4 with no problems, only my phone slowdown a bit Quote Link to comment Share on other sites More sharing options...
DKS Posted August 11, 2010 Report Share Posted August 11, 2010 I have an iphone with 4.0.1 software. I just upgraded this weekend with 1.1, 1.2, and 1.3. Previous owner didn't do much. I also took it to the dealer for the new 2.1 software. My phone and music are working as well as I can expect. Some things won't work like texting, but playing music throught bluetooth or the USB works perfectly well. My phone works fine. I have not messed with voice recognition yet because I just put it all together today and the heat index is over 110 here today. I may be just lucky but I, so far, have not had the issues I have read about. :yup: Quote Link to comment Share on other sites More sharing options...
chloe13 Posted August 14, 2010 Report Share Posted August 14, 2010 I have Sync 3.0 and just replaced my 3G with the iPhone 4 no problems. I didn't have any issue with the phonebook and the IP4, possible solution or reason being that I actually had accidentally turned off the autodownload option. Someone else over at Apple's forum also turned off autodownload, intentionally, after initially syncing his phonebook and now has no problem. Your contacts can always be synced manually after that whenever you feel like it needs it. I have an iphone with 4.0.1 software. I just upgraded this weekend with 1.1, 1.2, and 1.3. Previous owner didn't do much. I also took it to the dealer for the new 2.1 software. My phone and music are working as well as I can expect. Some things won't work like texting, but playing music throught bluetooth or the USB works perfectly well. My phone works fine. I have not messed with voice recognition yet because I just put it all together today and the heat index is over 110 here today. I may be just lucky but I, so far, have not had the issues I have read about. :yup: Quote Link to comment Share on other sites More sharing options...
Jon04CTSV Posted August 18, 2010 Report Share Posted August 18, 2010 Same problem. My iPhone4 works with Sync, but it cannot download my phonebook. Quote Link to comment Share on other sites More sharing options...
jukikee Posted September 18, 2010 Report Share Posted September 18, 2010 Same problem. My iPhone4 works with Sync, but it cannot download my phonebook. Same problem here too- My iPhone4 works with Sync but can't download my phonebook. At least, I don't know how to do it.... it doesn't happen automatically. Also, is there a way to have the car recognize the phone each time I get in? I'm having to go into the menu each time to find BT device.... Quote Link to comment Share on other sites More sharing options...
