bubbles Posted June 14, 2010 Report Share Posted June 14, 2010 My 2007 Edge has a transmission issue - it cruises fine on a flat stretch of road with the cruise control engaged but starts to "buck" noticeably as soon as a slight incline is encountered in the road. It has also been doing this when I accelerate slowly without using cruise control as well . I had the fluid flushed recently and it is still doing it. Any thoughts ?? Quote Link to comment Share on other sites More sharing options...
vtxsoreass Posted June 15, 2010 Report Share Posted June 15, 2010 My 2007 Edge has a transmission issue - it cruises fine on a flat stretch of road with the cruise control engaged but starts to "buck" noticeably as soon as a slight incline is encountered in the road. It has also been doing this when I accelerate slowly without using cruise control as well . I had the fluid flushed recently and it is still doing it. Any thoughts ?? My 2007 Edge is doing the same thing with 85,000 K on it. Base on a few other items I've read, it could very well be a faulty coil/plug. Remember, that engine has one coil per plug. The mechanic should be able to diagnose the problem with it plugged in while driving. Quote Link to comment Share on other sites More sharing options...
bubbles Posted June 15, 2010 Author Report Share Posted June 15, 2010 I am hoping that it has registered as a fault code when I take it in. Unfortunately my Edge has 71 500 K on it and I think that this is beyond warranty ?? I will ask my dealer about the coil / plug possibility - but will also examine the computer program update option as well... Guess I will let them look at it first. Please let me know how you make out with your tranny problem...thanks Quote Link to comment Share on other sites More sharing options...
tloewenberg Posted July 6, 2010 Report Share Posted July 6, 2010 I had the same elusive problem but while the car was still under warranty. It took 4 trips to the dealer before they caught the issue (same as yours). I originally was thinking transmission but it proved to be one of the cyclinder coils. Oh, one other thing. The problem was accurately predicted by another forum participant who also experienced the same issue. Eventually, the problem will become more predictable and repeatable. Quote Link to comment Share on other sites More sharing options...
bubbles Posted July 6, 2010 Author Report Share Posted July 6, 2010 I had the same elusive problem but while the car was still under warranty. It took 4 trips to the dealer before they caught the issue (same as yours). I originally was thinking transmission but it proved to be one of the cyclinder coils. Oh, one other thing. The problem was accurately predicted by another forum participant who also experienced the same issue. Eventually, the problem will become more predictable and repeatable. Thanks...you were right...the problem was a faulty coil over plug. My dealer says that it was cuased by a worn plug that was causing the coil to work harder to spark over the large gap. He recommended changing all plugs. Coil was $ 90 Cdn and plug $ 6 Cdn... Vehicle running normal again... Quote Link to comment Share on other sites More sharing options...
