mathieurochette Posted June 10, 2010 Report Share Posted June 10, 2010 just wondering if someone could give me a link to a detailed install of an HID kit with relay's installed on an Edge with DRL Thanks Matt Rochette Quote Link to comment Share on other sites More sharing options...
Lex Talionis Posted June 10, 2010 Report Share Posted June 10, 2010 There are several HID threads that cover it all. Might just use the search function... you can find them. Some have photos and some not. But, IIRC, there are only a few that show the relays. But plenty of details on where and how in those existing threads. Quote Link to comment Share on other sites More sharing options...
4DOOR2NV Posted June 15, 2010 Report Share Posted June 15, 2010 (edited) I just installed mine the other day. I'm guessing you have a wiring harness for your HID's. Connect the positive and negative to the battery, the toggle on wires plug right into the original socket. I can't really remember right now, but I think the positive lead goes to the yellow wire on the headlight socket. You will also need a capasitor / anti-flicker device. This goes in line with the toggle on wire. The DRL's don't provide enough power to activate the HID's. I hope this helps, if your in Toronto I can install it for you. I just did my fogs and headlights, the fogs were a biatch to install compared to the headlights. Mainly due to wire length and access from the bottom. ** I just saw your in Ottawa, I'll be in Brockville in 2 weeks if you wanna meet there I can install them for you.** Edited June 15, 2010 by 4DOOR2NV Quote Link to comment Share on other sites More sharing options...
