bensfords Posted June 7, 2010 Report Share Posted June 7, 2010 Anyone ever had their AC drain clogged? If so, what did you do to unclog it? Water is draining on the passenger side floor. Quote Link to comment Share on other sites More sharing options...
claas900 Posted June 7, 2010 Report Share Posted June 7, 2010 Never had one clog. But you should be able to crawl under the Edge and either fish a wire up the drain or use some compressed air. I cant think of a reason it would clog unless you drive in a lot of mud or something of the like? Quote Link to comment Share on other sites More sharing options...
StrongWind Posted June 8, 2010 Report Share Posted June 8, 2010 On 6/7/2010 at 9:21 PM, bensfords said: Anyone ever had their AC drain clogged? If so, what did you do to unclog it? Water is draining on the passenger side floor. Are you sure it's clogged or did the drain tube get knocked loose? I had truck one time that the drain tube would come off inside the cabin once or twice a year after I had the carpet vac'd at the car wash... Also, it is possible that you may have mold buildup on the evaporator. Had a Chrysler minivan a while back that would not drain well - mold would form in the evaporator box. Do you run your AC on recirculate all the time? It's a good idea to run some outside air through the system rather than keep in on recirc all the time. Good luck. SW Quote Link to comment Share on other sites More sharing options...
DrGuy Posted June 3, 2011 Report Share Posted June 3, 2011 Pete, Thanks for the info. I to looked for the condenser drain on the firewall to no avail. It was in the tunnel right where you said. Instead of wrestling with the wire; I took my air compresser and shot a blast of air up the drain. Water came gushing out right away. I waited till it stopped and then gave it another shot to make sure it didn't reclog. Now I need to wet vac the floor board carpet. Quote Link to comment Share on other sites More sharing options...
EdgeDog Posted August 21, 2014 Report Share Posted August 21, 2014 underneath to the right side of the gas pedal , under the carpet is the drain hose...underneath the truck pull back the front drivers side heat shield and u will see a white drain...put a shop vac on it and whalaaaa...just did it on mine...freeked me out when water came pouring in the passenger side and the fan motor hitting water was an interesting experience...hope it helps all...EdgeDog.. Quote Link to comment Share on other sites More sharing options...
EdgeDog Posted August 21, 2014 Report Share Posted August 21, 2014 heat shield under the doghouse, left of the catalytic coverter... Quote Link to comment Share on other sites More sharing options...
