mikelc2 Posted June 7, 2010 Report Share Posted June 7, 2010 I'm having some issues with my woofer. I had it replaced under warranty a few months ago because it was rattling. Now, and for the past few months, whenever I listen to music at about 30% volume while driving, the subwoofer will cut out for about two seconds, then come back to life again. It's rather annoying, especially seeing as I listen to fairly bassy music. The only time I was able to reproduce it (with the vehicle parked, I opened the power hatch) but since has not done it. I took it to the dealer when that happened and "everyone was on lunch" so they could not look at it. I have never had this issue before regardless of volume (although I will mention turning the volume down doesn't necessarily prevent it), and it is one that is extremely difficult to reproduce for the dealer. Anyone have any suggestions on what I might try or what it might be? Thanks in advance for any reply! Quote Link to comment Share on other sites More sharing options...
DJ Nap Posted June 8, 2010 Report Share Posted June 8, 2010 I'm having some issues with my woofer. I had it replaced under warranty a few months ago because it was rattling. Now, and for the past few months, whenever I listen to music at about 30% volume while driving, the subwoofer will cut out for about two seconds, then come back to life again. It's rather annoying, especially seeing as I listen to fairly bassy music. The only time I was able to reproduce it (with the vehicle parked, I opened the power hatch) but since has not done it. I took it to the dealer when that happened and "everyone was on lunch" so they could not look at it. I have never had this issue before regardless of volume (although I will mention turning the volume down doesn't necessarily prevent it), and it is one that is extremely difficult to reproduce for the dealer. Anyone have any suggestions on what I might try or what it might be? Thanks in advance for any reply! Do bumps/rough roads affect it? Sounds like a loose wire, most likely at the enclosure. Quote Link to comment Share on other sites More sharing options...
mikelc2 Posted June 26, 2010 Author Report Share Posted June 26, 2010 Do bumps/rough roads affect it? Sounds like a loose wire, most likely at the enclosure. I've narrowed it down so I can reproduce it, and I'm going to take it to a dealer when I have time. It seems to be electrical, or the AMP. It cuts out completely randomly while I'm driving, but oddly every time I open the power hatch it does it as well. Only for a second or so. Maybe it's not getting enough power? Quote Link to comment Share on other sites More sharing options...
