TuckerG Posted June 4, 2010 Report Share Posted June 4, 2010 I own a 2007 Edge and plan on buying new tires. My current tire size is 245/60R/18, and I want to go with a slightly wider tire...any recommendations? [ Quote Link to comment Share on other sites More sharing options...
akirby Posted June 4, 2010 Report Share Posted June 4, 2010 I own a 2007 Edge and plan on buying new tires. My current tire size is 245/60R/18, and I want to go with a slightly wider tire...any recommendations? [ 255/60R18? Seriously - you can go to a 255 or 265 size - you would just need to go to a 50 or 55 series to keep the overall size the same. Do a google search for tire diameter calculators and you can find a 50 or 55 series size with close to the same circumference. Just curious - why do you want wider tires? Quote Link to comment Share on other sites More sharing options...
EnemyAce Posted June 4, 2010 Report Share Posted June 4, 2010 I own a 2007 Edge and plan on buying new tires. My current tire size is 245/60R/18, and I want to go with a slightly wider tire...any recommendations? [ The stock 18" rim width for a 2007 Edge is 7.5". This means that you have a recommended 8.83" of actual tire width to play with. This can vary between manufacturers, but in most cases the widest safely you could go on a stock rim is 255. If you can find a shop willing to do it, you could conceivably go wider, but you'd be putting your safety at risk and most likey end up comprising the ride and handling. Quote Link to comment Share on other sites More sharing options...
