bubbles Posted June 1, 2010 Report Share Posted June 1, 2010 I want to change the transmission fluid on my 07 Edge. I found 2 small plugs on the casing that I am thinking must be drain plugs. They are positioned at 2 different levels on the tranny case. Does anyone know if these are drain plugs for the tranny fluid?? I want to drain and refill with new fluid. Will drive for a week and repeat. Any thoughts ?? Quote Link to comment Share on other sites More sharing options...
akirby Posted June 1, 2010 Report Share Posted June 1, 2010 I want to change the transmission fluid on my 07 Edge. I found 2 small plugs on the casing that I am thinking must be drain plugs. They are positioned at 2 different levels on the tranny case. Does anyone know if these are drain plugs for the tranny fluid?? I want to drain and refill with new fluid. Will drive for a week and repeat. Any thoughts ?? Don't bother. Take it to the dealer where they have a machine that will remove and replace 95% of the fluid. There is no need to repeat the procedure. Just draining the fluid won't get more than about half of the old fluid out. Quote Link to comment Share on other sites More sharing options...
bubbles Posted June 2, 2010 Author Report Share Posted June 2, 2010 Ya...probably good advise ! I have an email in to my local Ford dealer for a quote on the fluid flush...thanks... Quote Link to comment Share on other sites More sharing options...
spider9303 Posted December 28, 2010 Report Share Posted December 28, 2010 So what was the quote to change the transmission fluid? Could I guess maybe 250 to 300 dollars. Quote Link to comment Share on other sites More sharing options...
akirby Posted December 28, 2010 Report Share Posted December 28, 2010 So what was the quote to change the transmission fluid? Could I guess maybe 250 to 300 dollars. It should only be around $180 from what I remember. Quote Link to comment Share on other sites More sharing options...
Depiry Posted December 28, 2010 Report Share Posted December 28, 2010 (edited) The lower of the 2 drain plugs is the tranny fluid,easy job remove drain,relpace add approx 4.5 quarts of Motorcraft LV tranny Fluid, Check level while running,Marty AAMCO is advertising 95% oil change for $99. Edited December 29, 2010 by Depiry Quote Link to comment Share on other sites More sharing options...
