4DOOR2NV Posted May 28, 2010 Report Share Posted May 28, 2010 I took out my HID retro kit from my old car and I want to put it in my Edge. I know I need H11 bulbs, my question is can I just hook it up directly and it will work? Or do I need a capasitor or something extra to install them? Quote Link to comment Share on other sites More sharing options...
dd-bot Posted June 2, 2010 Report Share Posted June 2, 2010 you will need relays and capacitors, I don't remember how many uF for the capacitors, but I can check that out for you, I had my HID kit installed few months ago, It works great. Quote Link to comment Share on other sites More sharing options...
4DOOR2NV Posted June 7, 2010 Author Report Share Posted June 7, 2010 Over the weekend I installed my HID's for the low beams and fog lights. I did need a resistor due to DRL not putting enough wattage out and it started to flicker. I added a anti flicker device (resistor) and it works perfectly. As for the fogs, one good note to point out is that it is extremely cramped trying to get it from the bottom and you have to take off the harness before trying to twist out the bulb. I'll add a pic soon. Quote Link to comment Share on other sites More sharing options...
erne65 Posted June 22, 2010 Report Share Posted June 22, 2010 Over the weekend I installed my HID's for the low beams and fog lights. I did need a resistor due to DRL not putting enough wattage out and it started to flicker. I added a anti flicker device (resistor) and it works perfectly. As for the fogs, one good note to point out is that it is extremely cramped trying to get it from the bottom and you have to take off the harness before trying to twist out the bulb. I'll add a pic soon. Where did you purchase the resistor that you used? I have run into this flickering issue with mine and occassionally 1 of the headlights will not even turn on. Quote Link to comment Share on other sites More sharing options...
ThinLine Posted June 23, 2010 Report Share Posted June 23, 2010 For those of you who installed an HID kit and it actually works properly.....more power to you. If you have the automatic on headlights and you have had no issues.....I mean everything works like stock and both lights fire and stay on......chime in on what kit you have and price. Thanks. Quote Link to comment Share on other sites More sharing options...
kosh Posted June 23, 2010 Report Share Posted June 23, 2010 I have the Retro slim kit on my fogs, plug and play with no issues Quote Link to comment Share on other sites More sharing options...
Depiry Posted June 24, 2010 Report Share Posted June 24, 2010 (edited) I installed Hoen Digital Xen system,No capacitors or resistors required,Have a 2010 limited with auto head lamp control,no problems easy plug and play,comes with ty wraps and shrink tubing for lamp socket connection,Marty Also came with a free pair of yellow fog lamps. Edited June 24, 2010 by Depiry Quote Link to comment Share on other sites More sharing options...
Manny Domingues Posted July 18, 2010 Report Share Posted July 18, 2010 Ok so I am thinking about changing the lamps out fro HID. Can anyone advise why a vehicle with Auto Lights and DRL have issues requiring a Resistor or some other items. The DRL are actually the High Beams and I would not be changing those only the Low beams for now. Then maybe in the future the fogs. Don't use the High Beams enough to warrant changing them out. Your input / opinion is appreciated. Quote Link to comment Share on other sites More sharing options...
