Need help
Goodfriday
When turning only left, our Edge has a noise in the front passenger compartment. It's a noise that is under the glove box, & under the shroud cover the AC cooling unit. Removing this shroud causes water ( lots ) to fall on the floor mat. This happens when turning left, and when the air conditioning setting is on max. ac, and the fan is on 3 or 4.
What causes this noise, & is this noise under any recall notice?
Thanks in advance to all that reply! :redcard:
