jboozell Posted May 24, 2010 Report Share Posted May 24, 2010 I have a 2008 Edge Limited. It's loaded. I was using my thumb drive for listening to my music - about 27 GB worth. I took the thumb drive out and took off all of the preloaded crap that comes already on it and added more music - I now have about 30 GB of music on my thumb drive. This all copied from my own CD's and it worked fine before my changes. Now the system doesn't recognize the thumb drive when put into the USB port. Any advice or pointers out there? Quote Link to comment Share on other sites More sharing options...
MOFSTEEL Posted May 24, 2010 Report Share Posted May 24, 2010 (edited) Edited May 24, 2010 by MOFSTEEL Quote Link to comment Share on other sites More sharing options...
Lex Talionis Posted May 24, 2010 Report Share Posted May 24, 2010 are you sure the system did not set the default "User Device" back to BTST and away from USB. this is common. Quote Link to comment Share on other sites More sharing options...
Picturepro Posted May 25, 2010 Report Share Posted May 25, 2010 maybe the file format change in import. I had a problem with all my iTunes music. somehow everything was mp4 USB would not play Quote Link to comment Share on other sites More sharing options...
igcitng Posted May 25, 2010 Report Share Posted May 25, 2010 What 'preloaded crap' did you remove? You may have erased files or drivers. Quote Link to comment Share on other sites More sharing options...
Lex Talionis Posted May 25, 2010 Report Share Posted May 25, 2010 What 'preloaded crap' did you remove? You may have erased files or drivers. USB, no drivers needed on the drive itself. that is just 1 beauty of a USB drive. often, these thumb drives come with preloaded junk like apps or backup software or files if formatted as windows drive. Quote Link to comment Share on other sites More sharing options...
jboozell Posted May 26, 2010 Author Report Share Posted May 26, 2010 are you sure the system did not set the default "User Device" back to BTST and away from USB. this is common. Yep! Sure. Good point though! Quote Link to comment Share on other sites More sharing options...
jboozell Posted May 26, 2010 Author Report Share Posted May 26, 2010 maybe the file format change in import. I had a problem with all my iTunes music. somehow everything was mp4 USB would not play Great idea. I did not know this. I will check. Thanks! Quote Link to comment Share on other sites More sharing options...
