Baileyjack Posted May 23, 2010 Report Share Posted May 23, 2010 I have a 07 Edge and recently noticed the puddle bulb on the passenger side is out. Was just wondering how you replace it. I can't seem to get the lens off and don't really want to try to pry it till i find out if you pry it off or turn it. Funny the owners manual doesn't say anything about it. Also the local jobby doesn't carry the bulb for it, is it a dealer only? Thanks in advance. Quote Link to comment Share on other sites More sharing options...
Lex Talionis Posted May 24, 2010 Report Share Posted May 24, 2010 just take a small screw driver, or your finer tip, and push the little tab and that will allow you to pull it down. really rather easy, it is just the little tab that can be hard to actuate. I use a very small driver to get leverage. it is a dealer only bulb and in fact, there is no bulb to change per se, as it is an entire encased unit of bulb and housing. about $50 a pop! a total rip off from dealer. several of us here have cut the closed unit open - separate the lens from the body to get access to the tiny bulb - with a dremel tool and replaced the bulbs with LEDs.. search for those topics here as they have been covered. Quote Link to comment Share on other sites More sharing options...
Baileyjack Posted May 25, 2010 Author Report Share Posted May 25, 2010 just take a small screw driver, or your finer tip, and push the little tab and that will allow you to pull it down. really rather easy, it is just the little tab that can be hard to actuate. I use a very small driver to get leverage. it is a dealer only bulb and in fact, there is no bulb to change per se, as it is an entire encased unit of bulb and housing. about $50 a pop! a total rip off from dealer. several of us here have cut the closed unit open - separate the lens from the body to get access to the tiny bulb - with a dremel tool and replaced the bulbs with LEDs.. search for those topics here as they have been covered. Thanks very much, great info. I was unaware these were so expensive....will be searching out the how to on the lens.....8o) Quote Link to comment Share on other sites More sharing options...
Picturepro Posted May 25, 2010 Report Share Posted May 25, 2010 Is there any of the wiring there on SEL or just Sports and Limited?? Quote Link to comment Share on other sites More sharing options...
klc317 Posted May 31, 2010 Report Share Posted May 31, 2010 just take a small screw driver, or your finer tip, and push the little tab and that will allow you to pull it down. really rather easy, it is just the little tab that can be hard to actuate. I use a very small driver to get leverage. it is a dealer only bulb and in fact, there is no bulb to change per se, as it is an entire encased unit of bulb and housing. about $50 a pop! a total rip off from dealer. several of us here have cut the closed unit open - separate the lens from the body to get access to the tiny bulb - with a dremel tool and replaced the bulbs with LEDs.. search for those topics here as they have been covered. I've had mine out before, it's kind of scary the first time you do it because it feels like they are going to break but as Lex mentioned, once you do it it's fairly easy. Quote Link to comment Share on other sites More sharing options...
