Edge Grill kind of soft....
EdgyDon
Our chrome bars I believe is zinc coated ABS plastic which is softer than the rock piece/sand (density 1.0g/mL vs 2~5g/mL, same materiel used on 18" chrome wheel cover), especially when you hit them at high speed. Steel or Aluminum alloy certainly better(harder) than ABS in most case but they will be heavier and pricey, and you have to deal with the oxidization.
I have the same thing on mine, I will try some waxing at next wash. ;)
