Neil Posted May 15, 2010 Report Share Posted May 15, 2010 I just bought a 2008 New Navigation off ebay. no disc, No antenna. The disc I'm ok with as I know how to use torrents. However do i require anything else other then the head unit? Will i need to buy another antenna? Currently I have a 6CD AM/FM radio with Sync in a 2008 Edge Limited AWD. Thanks Quote Link to comment Share on other sites More sharing options...
klc317 Posted May 15, 2010 Report Share Posted May 15, 2010 (edited) I just bought a 2008 New Navigation off ebay. no disc, No antenna. The disc I'm ok with as I know how to use torrents. However do i require anything else other then the head unit? Will i need to buy another antenna? Currently I have a 6CD AM/FM radio with Sync in a 2008 Edge Limited AWD. Thanks You'll may need to get it programmed depending on if the vehicle it came from had the high end audio (Audiophile), a factory subwoofer, etc. and yours doesn't or vise versa. Just have to plug it in and try to see if things work or not. You may get lucky and not have to mess with it. I'm not sure how the SYNC works or if needs to be seperately programmed if you swap head units. As for the antenna, the one I got is a short-cable one that fits up inside the dash behind the radio. It's out of sight and doesn't require running and hiding any antenna cable. The Ford part number for it is 8G1Z-10E893-B Edited May 15, 2010 by klc317 Quote Link to comment Share on other sites More sharing options...
Neil Posted May 19, 2010 Author Report Share Posted May 19, 2010 Hi, My car is a 2008 Edge Limited AWD loaded except for Nav, The factory Sub woofer came with stock radio. The Nav I bought is 8E5T-18k931-AD which is a Pioneer AVN Audiophile NAV system from a 2008 Ford Fusion. I now know i need the Satellite Antenna but where can I get it programmed? Do i have to get it programmed in my edge or the edge programmed for the radio? Thanks for the help! Quote Link to comment Share on other sites More sharing options...
klc317 Posted May 20, 2010 Report Share Posted May 20, 2010 (edited) Just take a read through my topic. On the second page there is a link to an Ebay store that shows where I got my programming done. You send him the head unit and your vehicle specs and he does the rest.... http://www.fordedgeforum.com/index.php?/topic/4805-score/ Edited May 20, 2010 by klc317 Quote Link to comment Share on other sites More sharing options...
Neil Posted May 28, 2010 Author Report Share Posted May 28, 2010 Just take a read through my topic. On the second page there is a link to an Ebay store that shows where I got my programming done. You send him the head unit and your vehicle specs and he does the rest.... http://www.fordedgeforum.com/index.php?/topic/4805-score/ Thanks, Your post was helpful but My O8 edge had sync and bluetooth so a few other problems. At this point, I had a Car Audio store install the unit for me for $50, there are two funny screws at the top of the bezel under the rubber matt that I don't have tools for so FU it!. I would rather pay the $50 then look around all day! Sync works, bluetooth works. Steering wheel buttons don't work and Sub woofer is not active. Next Navigation I will now take it to ford to have them flash it. Quote Link to comment Share on other sites More sharing options...
