Warranty Issues
LAJAMA
Hi,
I am relatively new to this forum. I was wondering why there isn't a place for the 2007 Edge?
Since I couldn't find where 2007 Edges are discussed, I will ask my question here.
My Edge is just about ready to be off warranty.
Are there any things that I could check out on my 2007 Edge that may need to be taken care of before the warranty expires.
I appreciate any guidance that you can give me.
Thank you. :yup:
  On 4/14/2010 at 7:43 PM, LAJAMA said:
Hi,
Thank you. :yup:
Hi LAJAMA. :D What to have checked is highly subjective and depends on your particular vehicle. So the short story would be to check everything and make notes. Check every last nut and bolt that you can. If the transmission does not shift correctly. If the engine makes odd noises. If anything leaks. If anything creaks. If something that should not make noise makes noise. If something that should make noise does not. Or you can find anything else that is wrong or you think may be wrong, now is the time to have it checked, diagnosed and fixed under Warranty.
Other than that, there is nothing specific we can point you towards.
Let us know how you make out.
Good luck. :beerchug:
