Look What I have Done!!!
Reading on the Accessories and Modifications section of this forum made me do these things to my EDGE..... and I didn`t felt bad but rather GREAT!!!
1. Interior Blue LED Mood Lights tap into the Park Light On Switch....
2. Interior LED Courtesy Lights
3. Second row seat led light tap into the rear courtesy light power. Installed under the seat at the center
4. Center Console Courtesy LED light tap into cigarette lighter plug power supply. Installed with pin switch.
5. Back Plate LED light
Edited by drgnhurt
HIDCANADA
its a 35W Digital Ballast with 6000K bulb... nice color...
its a straight install.... no harness needed... straight plug and play...took me about 30 minutes to install.... hard part is drilling a hole on the passenger side... no room for the drill...
Where did you get your HID's and what's the type/color/brand?
nice mods. I have done them all myself nearly. my next one is that, rather than those lights you attached to the outside of the dash - 1st pict - I plan (have the LED and wiring already) to hide an LED into the top of the lower cubby hole roof. That way, light shines into the cubby hole and onto the little shelf, but it is hidden away so more ambient.
BTW, you should search for my light mod where I put one into the glove box. you might like that.
Mind you it's not neon.... it's blue LED accent light.... and I don't find it looking cheap.... the picture doesn't justify the way it look in person...
but anyway... to each is own.... you have your own taste.. I have mine
peace out
The neons attached to the dash make the car look cheap.
Other than that good job on the mods.
I'm glad my 2010 already came with ambient lighting and illuminated door sills.
