Aftermarket Performance
sntmods
I use to be a SCT dealer myself. Getting a tune does make your car run alot more efficient. IF you get the SCT custom tune. Your basic Diablo and Superchips tuners are generic. CAI, and tune will allow for better gas mileage and performance.
Kevin
Not to throw flames but Diablo and Superchips are not generic, Especially Diablo.
-Dan
I know Magnaflow has a cat back system that will be out soon they have it on there website but no cost yet!
( http://www.magnaflow.com/02product/shopdis...80&cat=Edge )
I I think simple "bolt ons" would be popular with the Edge so long as they increase horsepower and don't decrease mpg a lot. It would be nice to see both lowering and lift kits for this rig I think it could look really nice jacked up 2 inches or so with some BFG All-Terrain T/A KO 31" tires under there as well as sitting down a few inches again with some nice rims maybe some 22's even.
Anyway Its early in the life of the edge and I'm sure we will see an increase in aftermarket parts in the near feature
I checked their website & it says that more info will be available by August 18th.
I should better clarify myself. The basic Superchips programmers are generic tunes. What I mean by that is you see how the tuners will work for, lets say 99-2004 mustang Gt's. They are a VERY mild. As for Diablo, they are the same, unless you get the custom tune. As for SCT, the program is based off of your cars PCM. As for my mach 1. TMX4 was my PCM code. All PCM's have different adjustments. The mach 1 has 4-5 different codes I have seen. SCT goes into that specific PCM and adjust the features on the PCM only. As for the Superchips tuner can do all mach 1's. Reason is, they can only adjust timing so much. What they do is creat a tune on the weakest PCM. So when it starts to misfire in a cylinder, they back it back down and flash the tuners with the specific tune. That should clear it up for you guys and gals :)
Kevin
