ablb Posted March 19, 2010 Report Share Posted March 19, 2010 I know that candy bars and toilet paper are shrinking. BUT I didn’t know about oil filters! OR did I buy a WalMart made in China counterfeit? ab Quote Link to comment Share on other sites More sharing options...
sabtaj1 Posted March 20, 2010 Report Share Posted March 20, 2010 bigger is out and smaller is in. Now is a good time to be a midget. I dunno, thats crazy that they made the filter smaller. Quote Link to comment Share on other sites More sharing options...
Lex Talionis Posted March 20, 2010 Report Share Posted March 20, 2010 (edited) On 3/20/2010 at 12:05 AM, sabtaj1 said: bigger is out and smaller is in. Now is a good time to be a midget. I dunno, thats crazy that they made the filter smaller. ahh.. depends on the need I say for example, in my FJ40 with a small block 350 crate motor, I run a larger filter as that means I can fit in more oil and that means the cycle of oil takes longer and that helps keep things cooler as the oil takes longer to get back around as more of it. So, I think it just depends on the need. If you were doing a lot of towing, I would consider a larger filter for example. nevertheless, that is odd to see same part # and all.. hmm as I love conspiracy I say they made them smaller to increase wear and thus, cause you to have to need more maintenance :shades: Edited March 20, 2010 by Lex Talionis Quote Link to comment Share on other sites More sharing options...
hoss66 Posted March 20, 2010 Report Share Posted March 20, 2010 They have been making the filters smaller for about a year now. They say it is for easier installation and removal but also did it so they could save on shipping, the smaller filter size will result in the pallet quantity being increased by one layer or 120 pieces. There are no changes to the performance attributes of the oil filter. 1 Quote Link to comment Share on other sites More sharing options...
bender Posted March 20, 2010 Report Share Posted March 20, 2010 On 3/20/2010 at 3:41 AM, hoss66 said: They have been making the filters smaller for about a year now. They say it is for easier installation and removal but also did it so they could save on shipping, the smaller filter size will result in the pallet quantity being increased by one layer or 120 pieces. There are no changes to the performance attributes of the oil filter. There's going to be less filter media inside. I noticed this too when I did the first oil change, the factory un-numbered filter was taller than the example I bought at Ford. I thought maybe it was to keep the filter out of harms way for a Edge equipped with a engine oil cooler. Quote Link to comment Share on other sites More sharing options...
hoss66 Posted March 20, 2010 Report Share Posted March 20, 2010 On 3/20/2010 at 4:01 PM, bender said: There's going to be less filter media inside. I noticed this too when I did the first oil change, the factory un-numbered filter was taller than the example I bought at Ford. I thought maybe it was to keep the filter out of harms way for a Edge equipped with a engine oil cooler. Motorcraft added one more fold to the media to increase the filtering media surface over the old design. That means more filtration for the same filter. 1 Quote Link to comment Share on other sites More sharing options...
Tribby2001 Posted March 21, 2010 Report Share Posted March 21, 2010 (edited) Is the Motorcraft FL-500S oil filters used on the 2010 and presumably 2011 Edge larger or smaller than the new FL-400? The measured FL-500S filter dimensions are roughly, 4"L x 3"W x 9.5"Diameter As soon as a FL-500S aftermarket replacement becomes available I will be using Amsoil Ea Synthetic Nanofiber Oil Filters. http://www.amsoil.com/StoreFront/eao.aspx [i have no financial interest in Amsoil.] Edited March 21, 2010 by Tribby2001 Quote Link to comment Share on other sites More sharing options...
L1TECH Posted March 24, 2010 Report Share Posted March 24, 2010 On 3/20/2010 at 3:41 AM, hoss66 said: They have been making the filters smaller for about a year now. They say it is for easier installation and removal but also did it so they could save on shipping, the smaller filter size will result in the pallet quantity being increased by one layer or 120 pieces. There are no changes to the performance attributes of the oil filter. On 3/20/2010 at 4:56 PM, hoss66 said: Motorcraft added one more fold to the media to increase the filtering media surface over the old design. That means more filtration for the same filter. I would love to know where you get your information from Quote Link to comment Share on other sites More sharing options...
ablb Posted March 24, 2010 Author Report Share Posted March 24, 2010 My biggest worry is that I have now ADDED to much OIL. :stop: kidding… I’m just kidding!!! ab Quote Link to comment Share on other sites More sharing options...
hoss66 Posted March 25, 2010 Report Share Posted March 25, 2010 My first post was information from ford and the second one was from a member on another forum that works in the oil industry. Quote Link to comment Share on other sites More sharing options...
abowie Posted April 18, 2010 Report Share Posted April 18, 2010 On 3/20/2010 at 3:41 AM, hoss66 said: They have been making the filters smaller for about a year now. They say it is for easier installation and removal but also did it so they could save on shipping, the smaller filter size will result in the pallet quantity being increased by one layer or 120 pieces. There are no changes to the performance attributes of the oil filter. I guess the Edge will still take 5 and half quarts for oil change and the newer filter? Quote Link to comment Share on other sites More sharing options...
Grey Posted April 18, 2010 Report Share Posted April 18, 2010 It was a French Canadian thing ----multiply by 9/5 and add 32. I will guess that since so many of the applications can use the smaller filter can, there were economies of scale (lower material cost) to revise the FL-400 size. BTW, the FL-1, FL-300 and FL-400 interchange (from a fit standpoint) if there is clearance. I bought some FL-300's on clearance from WallyWorld. Quote Link to comment Share on other sites More sharing options...
MKX2007 Posted April 19, 2010 Report Share Posted April 19, 2010 On 4/18/2010 at 6:06 PM, Grey said: It was a French Canadian thing ----multiply by 9/5 and add 32. I will guess that since so many of the applications can use the smaller filter can, there were economies of scale (lower material cost) to revise the FL-400 size. BTW, the FL-1, FL-300 and FL-400 interchange (from a fit standpoint) if there is clearance. I bought some FL-300's on clearance from WallyWorld. I went to buy an FL-1 for my old Chrysler & that one has been shrunk also. From what I saw on the shelves, it appears this is an across the board change. Quote Link to comment Share on other sites More sharing options...
